Question about Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher does not drain after final rinse
Model 15838 does not empty after final rinse. Motor sounds like it is running, but I must activate cancel/drain button 2 - 4 times to get it to completely empty, Water in tub is still soapy. Just replaced the water inlet valve after advise that it may be letting in fresh water during final rinse/drain. That did not solve problem. Took drain hose off with water still in tub and I get a very small trickle of water coming out of drain hook-up.
5 Suggested Answers
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
SOURCE: My Kenmore under counter ultra wash dishwasher
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Posted on Oct 13, 2009
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
SOURCE: My Kenmore Ultra Wash III dishwasher 665.1584990
My Kenmore Ultra Wash III won't open the water valve. The pump starts and the heater turns on, but no water. Any ideas?
Posted on Jun 06, 2010
Kenmore ultra wash dishwasher odor
Is the drain line going over an upper edge before connecting to the sink drain line? Also try to make a rinse with white vinegar.
Jul 06, 2015 | Kenmore Dishwashers
Gene, I have a Kenmore Elite model # 665
Hey Steve,Sorry it took me so long to answer i was offline and my add is not supposed to displayed when i am off line so sorry about that.
Now then on that dishwasher with the hum and no water circulation it sounds as if the main wash motor is jammed up for some reason it could be that the motor itself is defective or as simple as something such a piece of debris such as broken glass or almost anything caught in the motor causing it to not turn on,by disassembling the wash motor you can see if something is caught in,if nothing is caught in its a (sorry to say) the motor itself thats bad and would need to replaced.The reason the water drains even though it will not circulate is because of the separate drain pump that is working Please reply back after disassembling the pump to check for debris if ya need further assistance.
Thanks for using Fixya.Com,GENE
Oct 18, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Water is not competed drained out after all wash rinse and dry cycles are complete. No signs of any leakage on floor or under machine.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Mar 20, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenmore ultra wash dishwasher won't drain tried
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 27, 2010 | Kenmore 16764 Dishwasher
Dishwasher runs for appx 14 min & stops washing half way thru wash cycle. Timer contunies to run. No drain pump out (nothing). Let dishwasher set idle for appx 1 hour and it will re-set. Set timer...
This sounds like something is stuck in the drain pump. You can remove the inner cover to look for obstructions. You have a dual purpose motor it does the both circulating and draining. The blockage is causing it to overheat and trip the thermal protector. You can remove the drain assembly from underneath if you don't find anything from above. There is a video at www.appliancehelponline.com/servicemanual.html that walks you thru most of this. It is a different model but pretty close.If you find no obstructions the motor may be failing.
Apr 08, 2010 | Whirlpool DU840CWD Dishwasher
Dishwasher hums
empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
Apr 16, 2017 | Kenmore Dishwashers
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
115 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
