Question about Whirlpool GGQ8831L Gas Dryer
Frigidaire gas front loading dryer smells from gas.
  • 1,031 Answers
Your gas dryer uses a lot of air, not just the air that blows out the vent but the air used to burn the gas ( natural or propane ) as well, This is sometimes caused by the filter not being completely clean. By this I am referring to the clogging of the screen from the use of fabric softener sheets. The chemicals in these sheets will, over a period of time, impair the air flow through the screen and cause the gas odor to become prominent not to mention the temperature to rise within the dryer. you can clean the filter with soapy water and a tooth brush about every other month and it keeps this from occurring. but if after that the smell gas continues ...turn off the gas valve to the dryer and call for service!
Posted on Feb 21, 2009
  • Starnley Johnwells
    Starnley Johnwells Feb 21, 2009
    hope this helps pls do let me know
5 Suggested Answers
Jimster
  • 240 Answers
SOURCE: Frigidaire Front Load Dryer
Reach inside the drum and feel the drum inserts to see if one of those has come loose. Sometimes you can have one of those screws back out and hit something on the inside. Could also be a bent drum (doubtful unless its been overloaded or abused real bad) a front slide is bad (would probably cause squeeking or grinding noise) or rear bering (also should squeek or grind). Good Luck!!! Jim
Posted on Sep 09, 2007
  • 146 Answers
SOURCE: front load dryer
Remove the front panel to get to it. Once you get the front panel off it is easy to remove the drum and replace the element. First remove the top then the front then you have it.
Posted on Dec 22, 2007
IFIXALL
  • 868 Answers
SOURCE: Frigidaire front load dryer
If its under the 1 year manufacturers warranty ,use it!
Posted on Jun 02, 2008
SOURCE: iDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Posted on Oct 05, 2011
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My frigidaire front load dryer has no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Gas dryer smells like gas heats up a little bit
The most common problem with gas dryers is the ignitor going bad....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 05, 2010 | Frigidaire FGQ332ES Gas Dryer
My dryer smells like smoke
just ry to run in on air dry for a while mayee wth dryersheets. charcoal and baking soda are also good at absorbing smell if you can find a way to implement them maybee baking sod box in dryer not running
Jul 09, 2009 | Frigidaire GLGQ2152ES Gas Dryer
No heat to our gas frigidaire dryer
Make sure the gas valve is opening, you'll smell gas. Second, check if the glow bar comes on or, if the thermal couple is lined up to the igniter.
Jun 30, 2009 | Frigidaire GLGQ2152ES Gas Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Jun 27, 2009 | Frigidaire Electric Dryer
Clothes smell like gas
STOP USING THE DRYER AND CALL A QUALIFIED SERVICE PERSON TO TEST ALL GAS LINE CONNECTIONS WITHIN THE UNIT!
A gas leak can cause a fire in your home. Although, we have always used a gas dryer, and the clothes do have a fresher smell to them than an electric dryer. Any gas which may be in the area would be consumed when the gas flame was burning as normally the pilot remains lit throughout the drying cycle.
Jan 24, 2009 | Kenmore 43142 Front Load Washer
Mildew smell on clothes
I have the same machines. Try using an old towel and detergent solution( use rubber gloves) and thouroughly clean the door seal. It can be just full of old lint, dirt, etc. in the grooves. Also try some oxyclean in your next load. That will help get rid of the odor also. These washers stay warm quite a long time and clothing will mildew fast in warm weather, but you probably already know that.
Aug 01, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool GGQ8831L Gas Dryer Logo
174 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
