Question about GE Washing Machines
Need to remove the agitator on a GE model WBXR1060T8WW washing machine. How do I remove it?
    President:
  • 2,976 Answers
Unscrew the top and pop the agitator up.
Posted on Feb 21, 2009
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    Need to know how to get agitator off a ge washing machine
    onthejob5130_7.jpgonthejob5130_1.gifthis should be a big help..remove agitator first ,if frozen hit top of agitator back and forth to losen it ,,,remove agitator coupling and you should have it,,,good luck
    Sep 12, 2011 | GE WDSR2080D Top Load Washer
    How to remove the agitator to remove a shirt that is caught
    according to GE if you have a model made after 1999 you need to have a GE technician remove the agitator as it requires a special tool. :(
    Dec 17, 2010 | GE Washing Machines
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    GE washer model WJRE555OH1WW - agitator free-wheels.
    First make sure the inner part of the agitator is not brocken.
    Remove the soap cap from the top of the agitator and with a torch, look down into the shaft. There is normally a nut which secures the agitator to the gearbox shaft. If the plastic around the nut is broken then the agitator moves freely.
    There may not be a problem with your gear box, then and relatively cheap to replace agitator.
    goodluck.
    Ash
    Oct 22, 2009 | GE Washing Machines
    GE profile washing machine won't agitate it spins out, drains,
    Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
    Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
    AGITATOR REMOVAL GE WASH MACHINE, MODEL WPSR3100
    If you remove the top cover to the agitator, inside you will see a I believe 9/16" nut.  Remove this to take the agitator off the shaft.
    Mar 12, 2009 | GE Profile WPSR3100W
    GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
    The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
    Dec 03, 2008 | GE WBSR3140DW Top Load Washer
    Agitator on washing machine
    Hi thanks for your question . Yhe only reason you would want to take the agitator off would be to remove the tub .And thats tye only reason thanks for the question The appliancd doc
    Sep 11, 2008 | GE WHRE5260E Top Load Washer
    Washing Machines Logo
    148 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
