Question about Campbell Hausfeld 3 1/2" Rh Fram Nailer
Campbell Hausfeld 3 1/2 framing nailer bends the nails
Campbell Hausfeld 3 1/2" framing nailer refurbished from Canadian Tire:
Never did work. It leaves the nails sticking out about 3/4" and bends them over. I've adjusted it as far as possible to no avail. Is there any solution that anyone knows? The warranty, if it had one, is over I'm sure.
  • Murray Ernst Apr 08, 2009
    my CH 28 degree 3 1/2 inch nailer does not drive the nails completely and bends the ends over is this adjustable?
    Problem Solver:
  • 12 Answers
It is not the best brand but, it should work for a few projects. Increase the air flow and make sure it is lubercated. It is designed to shoot nails into soft wood, like pine. It could be a o-ring blown or damaged, which is easy and inexpensive to repair. Good luck. Phil.
Posted on Dec 03, 2009
  • 24 Answers
The tool is being run with restricted air. Change fittings to industrial free fkow and make sure you have 3/8 hose.
Posted on Apr 15, 2009
What degree angle and gauge nail gun to iron force framing
Iron force nailers are made by Campbell Hausfeld. Information and parts for their nailers can be found at
Click on the nailers tab then framing nailers. "Good luck
Oct 18, 2014 | Tools & Hardware - Others
Will Campbell Hauser CHG00100AV nail #9 upholstery nail into wood door for decoration
"Hauser", eh? Campbell Hausfeld may be the brand you are referring to, unless you bought a really cheap knockoff of a really cheap product (or just can't bother to spell)
May 15, 2014 | Campbell Hausfeld CHG00100AV 1-1/4-Inch...
Does the campbell hausfeld model sb504000 2 inch nailer/stapler need an external air to get started?
Sb504000 works just fine with pressure range from 60 to 120 psi depending on material. Any small compressor will work great. Using the gun at max pressure will shorten the life of the gun. Best practice is to set pressure to just under 100psi for most work and increase pressure when nailing hard wood. Using at max pressure will strain the driver and the lower part of gun (screws that hold nose to body). Some hard woods will bend an 18 gauge nail. Good luck with your gun and have fun with your projects.
Aug 11, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
My campbell hausfeld 3 1/2 nailer has been working fine, just today will it started misfiring. It would put out one nail, fire again -no nail. It seemed to be every other one, then it would be good, then...
Use wd 40,and spray it in the air input hole,where you connect the air line,and use the nailer,multiple times,then oil the slides for the nail hopper,and then after you do this,re oil with tool oil.If this was helpful,please rate.
Jul 05, 2010 | Air Tools & Compressors
Piston blade won't retract
I've had a similar problem and found a nail had broken and lodged itself in the nail housing causing the driver to get stuck forward.
Apr 22, 2010 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
May 08, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Will model no. ifn21950 shoot paslode 2
I would not recommend. Contact Campbell Hausfeld .com and order nails. You could damage your nail driver plunger if not careful. Plead rate . Thanks
Mar 27, 2009 | Campbell Hausfeld Tools & Hardware -...
Campbell Hausfeld NS2190MVRB 21 Degree Round Head Framing Nailer is jammed. How do I clear it?
Remove any nails in the magazine, and you can carefully take a pin pinch of a size that fits into the nose (where the nails come out). Try to carefully tap the driver back into the gun.This will sometimes clear the jambed nail. If the driver is severely jambed you will have to dismantle the entire unit to separate the driver from the nose of the nailer.
Mar 24, 2009 | Campbell Hausfeld Tools & Hardware -...
Campbell Hausfeld 3 1/2" Rh Fram Nailer Logo
465 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
