Question about Lenovo ThinkPad R61e Notebook
The cd drive will not open - Lenovo ThinkPad R61e Notebook
    Novelist:
  • 148 Answers
there is a tiny hole in front of the cdrom drive you put in a pin and push it cd rom drive will open out
here is an helpfull video works for laptop desktop
http://www.youtube.com/watch?v=EjOBQWSjrg0
Further Queries are welcom
please do rate me if you find my solution helpfull
Posted on Feb 21, 2009
    President:
  • 2,653 Answers
Unbend a paperclip or use a toothpick and push it into the round hole on the cd / dvd drive. It will force the drive open.
Cd drive wont open or run cds
Try re-seating the cables on the CD drive and where it connects to the motherboard.
Reboot the computer and go into the BIOS and check if the CD drive is detected. If the CD drive is not detected in the BIOS then the CD drive is faulty and needs to be replaced.
Mar 03, 2013 | Computers & Internet
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
I don't know how to open the CD compartment on this laptop.
Open My Computer, right click on the icon for the cd unit and click Eject.
Dec 04, 2010 | Dell Latitude D600 Notebook
Audio cd placed in cd drive is stuck; drive won't open. How can I get it open?
Next to push button here is a tiny hole. Insert a small pin through it a nd press the lever. It should open
OR
Open the music programme there in your computer. On the drop down menu click on EJECT and CD drive should open.
Dec 08, 2009 | HP Pavilion ZE4400 series: 1170B01-90...
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
Was able to put CD in drive but can not get drive to open and take CD out. Tried to restart computer but still will not release.
There may be a small pinhole on the front of the CD drive- push it with an opened paperclip, and it will release the drive.
Mar 14, 2009 | Computers & Internet
Cd rom
There are very many problems that It could be when you cannot open the cd rom drive, the best way to find out the problem would be to remove the drive that wont open and open the top, have a look inside and see if there is anything that could be causing this.
If you had a more detailed problem then people might have better answers. sorry
Dec 27, 2007 | Samsung (SC-152) Internal 52x CD-ROM Drive
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Lenovo ThinkPad R61e Notebook Logo
141 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
