Question about Nikon D80 Digital Camera with 18-135mm Lens
How do I disable the shutter release button noise?
    Scholar:
  • 48 Answers
In Menu mode, Beep is the second item (first is Reset) on the Custom Settings -- the pencil symbol on the left. Only two choices, on or off, for all uses of the beep. That means if you set it to Off it won't ever beep, even for stuff like the self-timer countdown.
Posted on Feb 25, 2009
cammedic
  • 667 Answers
SOURCE: Stuck shutter release button on my D100
Ouch...
The damage may require parts, but maybe not. If I were doing the work, I would charge in the $50-$60 range , plus parts if needed.
Nikon will likely quote you much higher $200+
You can use the repair service locater here on Fixya to find a repair shop in your area
Posted on Mar 24, 2008
SOURCE: nikon d40
I had exactly the same problem, i tried everything,battery out, sd card out , lens off etc...nothing worked.Completely by chance and irritation i repeatedly pressed the shutter butten over and over
( without the lens attached ) till it didn't react at all.On my LCD i got a normal menu so i put the lens on and bingo it was fixed, still works fine.I think maybe the shutter was out of alignment.
Hope this works for you.
Olly
Posted on Jun 01, 2008
dbmar111
SOURCE: shutter release button problum
U have this problem and contemplating whether the price of repair will be worth it. But anyway I was doing a shoot today and I couldn't press anything out of it. I took out my cable release and I got through it.
Posted on Feb 21, 2009
tbreeze47
  • 3083 Answers
SOURCE: when pushing the shutter release button a clicking
You're having a lens problem when the picture is blurry. There are a number of things you can try to fix it for free, but sometimes there is a broken or stripped part in the lens assembly that requires service. Here is a site that explains all the things you can try first to fix it. They say you can fix about 1/2 the problems, so it's worth a try. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The page is dedicated you lens error codes, but also applies to non-focusing problems. Good luck, it's a nice camera and well worth fixing.
Posted on Apr 06, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: Shutter does not activate and I am unable to view
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Posted on Feb 12, 2011
How to enable and disable movie-record button?
To use the movie-record button, your camera must be in the live view mode.
When you are using the viewfinder (DSLR mode) you only can shoot stills. in live view, you can shoot movies with the little red Movie-record button and shoot stills with the shutter release button.
Sep 05, 2014 | Nikon D5300 24.2 Megapixel Digital SLR...
Fuji s2700hd
I'm afraid this camera does not have any possibility to do manual focus. Not with stills and for sure not with recording video.
The only thing to help you focus on a certain object, that is not in the centre of the frame, is the focus lock. You have to point at the object you want to focus on, then press focus lock and than you can choose the composition you want to shoot. Focus lock occurs when you press the shutter release button half.
For video, the manual only says put the rail on the film camera and press the shutter release button once. The video will be stopped after 12 seconds. (or when you press the button again.
That is all.
Nov 21, 2013 | Fujitsu Cameras
My shutter release button on my Nikon P500 is not working. I press it half way and it will focus, but, when I press it full down it will not capture the picture. It started happening suddenly last week....
Try pressing the "Menu" button and disable "Active-D Lighting", also try setting the "Autofocus mode" to "Single". When the camera is off, press the shutter release and twist with the zoom know back and forth. Hopefully that fixes it! It worked for my P500 with the same problem.
Sep 25, 2013 | Nikon Cameras
Olympus E-300 Evolt when you press the shutter button to take a picture, the shutter rapidly repets for about 9 times
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 27, 2011 | Olympus Cameras
Error code says press shutter release button again
I e-mailed nikon for this same problem. Their solution was to take out the memory card and press the shutter release button in the demo mode. To get to the demo mode you first need to go to custom menu/controls/no memory card?/press ok/ arrow down to enable release and press ok. Now you are ready to try solving this problem. Press the shutter release button to see if it will reset the shutter release button. I haven't tried it yet but it is worth a try.
Aug 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Faulty nikon d40
That may be the best advice :
http://nikon.com/
Jun 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Shutter problem
Before you go to the Nikon service,turn off the camera and try the reset switch near the USB connector,good luck.
Mar 31, 2008 | Nikon D40x Digital Camera
Nikon D40 shutter is not releasing err is releasing butten again but same prob
I had the same problem. I sent my camera to the Nikon Service Center. They fixed it within three days. They actually replaced the whole aperture frame. FREE OF CHARGE AS LONG WITHIN THE WARRANTY PERIOD.
Jan 22, 2008 | Nikon D40x Digital Camera
Shutter-release
After the focus is confirmed, the Shutter-release time lag for the DiMAGE E201 is approximately 0.4 second. If the shutter-release button is depressed in a quick motion without making any pause to confirm focus, approximately 1.9 second is necessary.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
321 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
