Question about Whirlpool ED2FHEXN Side by Side Refrigerator
We have a whirlpool freezer on top but the bottom of the fridge is freezing
  • Whirlpool Master
  • 3,361 Answers
Set both freezer and fresh food controls to their mid position.
If after 24 hours the temp is still too cold replace the thermostat aka cold control.
Posted on Feb 22, 2009
Whirlpool ed22pq refrigerator
It needs repair, better contact whirlpool service center to fix it.
Feb 01, 2014 | Refrigerators
Water accumalating in the bottom of the fridge.
A common problem. All modern refrigerators have an automatic deicer. The heater kicks in, then MELTS the ice in build up in the freezer for a short period before freezing again. This water drains either in the fridge or out the back to the catch tray. Simply pull out the bottom drawers and clean the clogged drain hold where the water can drain and evaporate in the catch tray as it is designed to.
Mar 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool bottom freezer 5 years old everything freezes in the fridge
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Everything freezes in the refrigerator bottom drawers - no matter what we set the temp in the freezer or refrigerator, everythign freezes.
Make sure the vents from the freezer to the fridge are not blocked by ice etc. One is at the bottom and one at the top. The on at the top is adjusted open or closed when you adjust the fridge temp. Make sure it's working. Also make sure the fan in the freezer is circulating the air from the freezer through the vent at the top.
Aug 25, 2009 | Whirlpool ED2GHEXN Side by Side...
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Whirlpool refrigirator with top freezer
run your hand around bottom door seal see if you can feel a warm spot, if you do check that area for contamanation ie;particals of food etc if not pull the seal in that area back slightly see if seal is split.if all seems ok look at the drain hole at the back of your fridge inside it often clogs up with small particals of food if this is the problem use a pipe cleaner to clean it.if its cloged water will be seen lying at the bottom of your fridge ;if any of the above do not cure your problem turn down your fridge a little this will not affect your freezer.hope this helps you.adrian
Jan 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
83 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
