Question about EliteGroup P4VMM2 Motherboard
GameGirlX@aol.com ORIGINAL QUESTION: I am so confused - completely lost sound posted by gamegirlx on Feb 20, 2009 I am so confused - completely lost sound - reinstalled original drivers cd - reformatted 5 times - getting so tired...don't know what to do. I have p4VMM2 v1.0 - have searched the sites lowest I can find is V1.3 - I used those drivers still no sound. I did not flash the bios because if this isn't the correct version I don't want to kill the PC. I see other versions all the way up to: EliteGroup P4VMM2 PCB 8.0 Sound driver Realtek AC'97 Audio Driver. Update to support new model KM266PRO-M2 ; CD 2.6VI Does this mean that version 8.0's 4 in 1, sound, vga and bios are all updates for V1.0 or is 8.0 actually a whole different version of the motherboard? Please help - I have been trying to fix for 3 wks - absolutely NO errors on the hardware page and everything is turned up, turned on and not muted...I am so desperate - nothing was installed to cause the failure - the most I can figure is that windows update to XPSP3 killed or blocked something - was unable to get it back from restores before finally reformatting. FARCRY1010 RESPONSE: Solution #1posted on Feb 20, 2009 Farcry1010 Rank: Wiz Rating: 88%, 5 votes if you are afraid to update the bios i dont blame you dont do it. If the bios updates and your processor is no longer supported becasue the amount of size of the bios chihps memory the manufacture can only put in a limited amount of info so dont update bios. If i were you i would go into control panel and remove any audio software related to your sound card. Then go into the device manager( right click my computer' then properties. then device manager and then scroll down to sounds video and game cont. and expand this . see if there is a sound card installed if so remove it as well as all software related to it. After this at top of device man. screen click on scan for changes . when it finds your sound card you will get a prompt to search everytwhere this includes the internet agree to do this ......then you might get another prompt to go online agree to this. see if this helps. oh i forgot to mentioin to make sure those speakers do work GAMEGIRLX@aol.com RESPONSE: Quick details: O/S Model Windows XP Home Edition Service Pack 2 (build 2600) ECS P4VMM2 1.0 Enclosure Type: Desktop Processor a Main Circuit Board b 2.00 gigahertz Intel Pentium 4 8 kilobyte primary memory cache 512 kilobyte secondary memory cache Board: ECS P4VMM2 1.0 Bus Clock: 100 megahertz BIOS: American Megatrends Inc. 07.00T 04/02/01 Drives Memory Modules c,d 77.91 Gigabytes Usable Hard Drive Capacity 61.13 Gigabytes Hard Drive Free Space Multimedia Controller (3x) MPU-401 Compatible MIDI Device Standard Game Port VIA AC'97 Audio Controller (WDM) Loaded orig'l mainboard cd ver 1.4VI-didn't work Looked for updated drivers and used everything but BIOS at http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=46&DetailName=Bios&DetailDesc=P4VMM2(V1.1A)&CategoryID=1&MenuID=39&LanID=8 I Thank you so much for your kind response - I have performed those steps multiple times to no avail. Plugged current speakers into another pc -works great. Plugged different speakers into this pc - still no sound. I have even reset jumper to clear the cmos - no luck. I have searched every tech board I could find and many people have the same problem with no solution. I was kind of stuck on the following article I found believing this was my problem but no matter how many times I reformatted and performed the steps I cannot get KB888111 to install and show UAA in system hardware device. Could you please read and let me know If I am on the wrong path to a solution - maybe I am just not loading the right AC'97 drivers - do you have a link? When I load the drivers...do I need to load something like REALTEK audio or VIA Enhanced AC'97 codecs and drivers? Didn't have anything like that loaded originally - just the actual mainboard drivers. Steps I performed on fix listed below: Reformatted to XP SP1A and loaded a previous version of fix below KB835221 - didn't work - uninstalled KB835221 - went to XP SP2 and performed KB888111 fix without changing the registry - nothing - uninstalled upgraded to XP SP3 did KB888111 changing the registry - nothing...add/remove hardware shows KB888111 installed but system device driver does not show anything relating to UAA. Windows media Player and Winamp think that audio is working fine - no errors at all in system hardware device for sounds - actual PC makes system sounds but from the system not the speakers. Windows Audio-set to automatic and started Bios onboard AC'97 - enabled I have deleted everything and let the system search and re-install - still nothing I have read hundreds of articles published by different groups - Audio is no longer a mystery to me - seems pretty straightforward - I am stumped. The FIX Article: http://www.tech-archive.net/Archive/WinXP/microsoft.public.windowsxp.setup_deployment/2008-05/msg00213.html Excerpt from the article: UAA HD AUDIO DEVICE SUPPORT IN WINDOWS XP SP3 This is another MS nasty for all the deployment folks pushing XP SP3 to computers with UAA HD Audio devices. Yes SP3 will support the devices and the drivers are included however,, the patch IS NOT included! The update to KB835221, KB888111 doesn't link to the download but instructs you to call MS Support to get the patch which doesn't work on SP3. This patch is required before any of the HD device drivers are installed and should included in the reference PC image therefore, apply this before sysprep and capture. 1. On the reference PC change the CSDVersion registry key to reflect XP SP2: a. HKLMSYSTEMCurrentControlSetControlWindowsCSDVersion value=200 (use512 when scripting) 2. Restart the PC 3. Install KB888111xpsp2.exe (follow the link below and rename KB888111XPSP2.txt to .exe) 4. Change the CSDVersion key back to reflect XP SP3 again: a. HKLMSYSTEMCurrentControlSetControlWindowsCSDVersion value=300 (use768 when scripting) 5. Restart the PC, finalize configuration of the reference PC, sysprep and capture. You'll need to obtain the KB888111 patch, Code for 2 SMS installer Question: 1. (Do I even have UAA HD AUDIO capabilities?) 2. Can I load the 8.0 sound driver above without damaging my system? 3. Is the 8.0 AC'97 driver the latest release for 1.0 chip or is it a different motherboard? Feel free ro crroberate with as many wonderful people like you who might have another suggestion I'll try anything Thanks so much in advance for your efforts P
  • 3 more comments
  • gamegirlx Feb 25, 2009
    RescueTechLA
    Thanks for your reply - I have considered that as my problem. I don't know how to figure out exactly name/brand to buy. The slots on this board are different from my other PC's and the cards that I have (6) won't fit. Could you please tell me exactly which one I should buy?
    You're help is much appreciated - Thank You
    GameGirlX
    We have staples, office depot, walmart or target.
    Tried windows update - doesn't offer me any other driver
    went to manufacture site and reloaded what I thought was an update to the version I have and still no sound
    RescueTechLA
    Gotta send you a hug - thanks so much
    I'll update this later and let you know if it works.
  • gamegirlx Apr 07, 2009
    To: RescueTechLa
    You suggested a pci soundcard to fix my pc about a month ago...
    Just wanted to say...!!!!Thank You!!!! it was an easy and cheap solution
    and it worked beautifully...GameGirlX
    President:
  • 2,653 Answers
OK let me start by saying I didn't ready any of the above. The simple answer is to buy a pci sound card. That will take care of the problem cheap and fast. It's likely that your onboard sound died on the motherboard. I used to own that board and random things would fail on it all the time.
Sound card should run you $20 or less.
Posted on Feb 21, 2009
  • 1 more comment
  • RescueTechLA
    RescueTechLA Feb 25, 2009
    Is there a Best Buy or other major retail chain close to you that sells parts?
    Or did you want to purchase a sound card online?
    Have you visited the Windows Update site and if so have you tried using the "custom" update?
  • RescueTechLA
    ANY one like this one will do.
    Just so long as it's PCI
    http://www.officedepot.com/a/products/29...
    It says delivery only but I'm certain that they can ship it direct to the store for you. Or you could try stopping by any of the other stores you listed.
    Best of luck!
  • RescueTechLA
    No problem.
    Glad to help!
4 Suggested Answers
  • 85 Answers
SOURCE: I am so confused - completely lost sound -
if you are afraid to update the bios i dont blame you dont do it. If the bios updates and your processor is no longer supported becasue the amount of size of the bios chihps memory the manufacture can only put in a limited amount of info so dont update bios. If i were you i would go into control panel and remove any audio software related to your sound card. Then go into the device manager( right click my computer' then properties. then device manager and then scroll down to sounds video and game cont. and expand this . see if there is a sound card installed if so remove it as well as all software related to it. After this at top of device man. screen click on scan for changes . when it finds your sound card you will get a prompt to search everytwhere this includes the internet agree to do this ......then you might get another prompt to go online agree to this. see if this helps. oh i forgot to mentioin to make sure those speakers do work if you can plug them into another computer or vice versa see if you can borrow a little set of speakers from someone and see if those work. and make sure to plug into green port on back closest to your monitor cable. let me know how you made out and good luck
Posted on Feb 20, 2009
  • 10 Answers
SOURCE: ecs p4vmm2 v1 motherboard windows xp pro sp 2 can`t get sound
you din't install sound card...go google find vinyl deck..n download it....gd luck
Posted on Aug 01, 2009
  • 4 Answers
SOURCE: Is it possible to run vista aero on EliteGroup km400-m2?
Vista Aero is dependent on your Graphics hardware, not on your motherboard. The onboard VIA/S3G is not going to be capable of running Aero, but you do have an AGP 8x port that you could buy a card for. Try picking up an ATI 48xx series card if you plan on doing some gaming. If you just want to run Aero, however, just about any card nVidia 76xx series, 86xx, 96xx, or any ATI 26xx, 36xx, or 46xx series card will do.
Posted on Oct 19, 2009
Oil leak on left side of snowmobile. Riding at 50 mph and all of the sudden oil was spilling on left side. snowmobile still ran. what is leak?
Nytro- Oil leaking When on it's side [Archive] - SnoWest ...
www.snowest.com/forum/archive/index.php/t-44412.html
Dec 13, 2007 - 12 posts - ‎9 authors
Edit: When on it's left side and the oil is warm, i would say I lost about a quart in 30 minutes, just doesn't seem right to me. I will try to find where ... RMK 900 Oil Leak...
Nov 28, 2011
Something is leaking....from where?
Jul 19, 2011
roll over a four stroke?
Mar 16, 2011
oil leak
1 post
Jan 15, 2010
More results from www.snowest.com
Oil leak/ Bone Headed Move? ' TY4stroke '' Snowmobile Forum ...
www.ty4stroke.com > ... > Forums > 4 Stroke Forum > RS General Talk
Apr 6, 2014 - 12 posts - ‎6 authors
If you put the sled on its left side, you probably would have oil leak out an overflow tube, as oil would probably get into the airbox, and leak into ... Possible oil leak RS GT ' TY4stroke '' Snowmobile ...
Feb 28, 2015
Oil Leak ' TY4stroke '' Snowmobile Forum '' Yamaha ...
Dec 7, 2014
CRAZY OIL LEAK ' TY4stroke '' Snowmobile Forum ...
Feb 15, 2014
Oil leaking......help??? - TY4stroke '' Snowmobile ...
Jan 22, 2012
More results from www.ty4stroke.com
I have an oil leak - HCS Snowmobile Forums
www.hardcoresledder.com > ... > ZR/ZL forum
Jan 25, 2016 | Cars & Trucks
If I delete and re-install my AOL account will it delete all saved email?
AOL Desktop Software: Installing and Uninstalling - AOL Help
https://help.aol.com/.../aol-desktop-software-installing-and-uninstalli...
AOLLearn how to install and uninstall the AOL Desktop Software. ... Help MainAOL's All-In-One Desktop SoftwareAOL Desktop Software: Installing and Uninstalling.
How do I uninstall the AOL Desktop Software? - AOL Help
https://help.aol.com/.../how-do-i-uninstall-the-aol-desktop-software
AOLOct 4, 2015 - My Account; Sign Out ... Uninstalling the AOL Desktop Software removes all Usernames and settings ... IMPORTANT: If you have saved your AOLpassword on the AOL ... because uninstalling the software will delete your savedpassword. If ... To do so, you will need to remember the answer to your Account ...
If I uninstall AOL 9.1 and reinstall it, will I lose my data (ex ...
askville.amazon.com > Computers > Internet
Feb 28, 2009 - If so, will I lose my data (ex. address book, saved emails, etc.)? ... Ifyou completely uninstall the AOL software, all your screen names and ... When prompted by the User Account Control message, click the Continue button. 6.
Jan 21, 2016 | Le Pan II 9.7" Tablet PC
I have a 2000 Oldsmobile alero and I can't get any sound out of my rear speakers good speakers and connection just can't get any sound out of them
Installing/Replacing rear speakers in a 2002 Pontiac Grand ...
? 5:11
https://www.youtube.com/watch?v=aiWwA6bXvhE
Nov 30, 2010 - Uploaded by Turbo231
Installing/Replacing rear speakers in a 2002 Pontiac Grand Prix GT DIY ... same as a 2000 grand prix ...
How to remove back speakers and install in a 98 02 ...
? 17:50
https://www.youtube.com/watch?v=pIxGeqy9QYI
Feb 26, 2014 - Uploaded by Can't Kill Me
How to remove back speakers and install in a 98 02 Oldsmobile Intrigue. Can't Kill Me ... 6x9 Rear Car ...
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
how do you replace rear speakers? - Aleromod.com
www.aleromod.com > ... > General Help > Audio, Video & Security
Feb 13, 2013 - 20 posts - ‎7 authors
I just tryed it and I have no idea how to take that plasic thing out! ... I replaced the deckspeakers on my alero as well as my friends and didn't .... remove the rear deck...next thing is that if you have monsoon sound let ... Get better aftermarket speakers and then say ehh...i wanna go back to the weak stockers. Stero Question
May 21, 2013
Monsoon and aftermarket speakers
Sep 9, 2011
Aftermarket Headunits, Wiring Harnesses
Feb 19, 2004
Installing Aftermarket Radio, 2001-2004
Nov 20, 2003
More results from www.aleromod.com
Jan 21, 2016 | Oldsmobile Cars & Trucks
Touch sensitivity not working in my pen.
Reasons Why PEN PRESSURE Isn't Working (Viewer ...
? 4:04
https://www.youtube.com/watch?v=lHPRyDgGErY
Feb 1, 2015 - Uploaded by Aaron Rutten
I recently got a new tablet because my old one was broken. ....you find that you have lost pen tablet pressure sensitivity this will fix the problem: ...
pressure sensitivity of Wacom tablet not working anymore - Adobe ...
https://forums.adobe.com/thread/1152988?tstart=0
Adobe Systems
Oct 9, 2015 - 40 posts - ‎26 authors
I have no idea why, but the pressure sensitivity of my tablet won't work anymore. ...The tablet and pen are working within Windows. ..... Control Panel >Pen and Touch > Press and Hold then disabled the check-box Enable ... Wacom pen pressure issue, possible solution. ' Adobe ...
Dec 17, 2015
tablet + pen pressure + illustrator CS5 issue ' Adobe ...
Nov 27, 2015
Bamboo Pen Pressure not working in Illustrator ...
Feb 6, 2013
More results from forums.adobe.com
Why isn't my pen pressure sensitivity working? ' Wacom
Jan 19, 2016 | Genius Computers & Internet
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Blinking power supply LED
Your power supply is fried. I had the same problem with my Bestec ATX 250 power supply. I fixed the problem by installing the StatTech model: ATXPOWER250. It was easy to install and works well. It is almost identical to the original but more quiet. I got it for $29 at MicroCenter.com. Also at online Newegg.com, Radioshack.com, Provantage.com, June 20,2009
Jun 07, 2009 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Freezed on loading screen !!!!!!!!!
Hi, the original R4 revolution will only worked up to kernel 1.16 or 1.17 or 1.18 (cant remember its one of them). Anything that is higher than that are for the R4 SDHC and others (different type). R4 Cards can be pretty confusing as there are many types (original v2, v3, SDHC, supercard...etc) and they all have their own website. Cant remember the link to the original one but you can get the software at http://nds-gear.com/software-r4v2.zip
Hopefully this one should work for you
Feb 02, 2009 | Nintendo DS Lite Console
Gateway DVDRW
Hope I didn't confuse any of you by where & how I posted my problems. AM VERY NEW HERE, but kinda desperate
vegaspl@aol.com
Jun 14, 2008 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
872 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
