Question about Canon i860 InkJet Photo Printer
Using attachment to print 4x6 photos
How do you sert the attachment up to print small photos. Having difficulty getting the device to work
  • 49 Answers
The usual cause of this problem is too much 8 1/2 by 11 inch paper in the normal feed slot. Take most or all of the regular paper out of the tray before setting the photo feeder onto the front of the paper slot. When installing the photo feeder, make sure the photo paper container is extended by turning the big dial to the 2 o'clock position, then rotate the dial to the 10 o'clock position after the feeder is in position. Don't overfill either the photo feeder or the regular paper tray. It's pretty fussy about position and fit of the paper in the photo feeder.
Posted on Feb 24, 2009
Can I print small photos Using 4x6 photo paper??
you can print more photos per page but it requires you to set up the page and the number of photos on the page
one of your photo shop programs will have that ability and it will take some trial and error to get the right results
basically it will work like this select a photo and insert it on to a page
select another photo and insert it onto the same page next to the first one and so on until you have a page full
the page can be sectioned into squares as well
when you have what you want go to print preview and if that is working then print
after that use a sliding paper cutter to cut the photos from the page
Sep 04, 2016 | HP Envy 4500 e-All-In-One Printer, Copier,...
My mfc 615w brother printer says i got wrong paper size have it set to 4x6 and will not print photos
You can attach photo to full size sheet (as an option),
if a document is too small it may not detect and will not
print.
Oct 28, 2013 | Brother MFC-640CW All-In-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
How to load 4X6 photo paper
hi
  • Turn on the Epson 875DC and the attached computer. Make sure the cable between the two devices is securely in place.
  • Step 2 Remove any paper that is in the printer's feeder tray. Place the 4x6 photo paper printable side up in the tray, with the support sheet at the bottom of the stack of photo paper. Adjust the paper guides so they are pressed against the margins of the paper.
  • Step 3 Open the photos to be printed in your computer software program of choice. When you are ready to print the photos, click on the "File" link at the top of the window, then choose "Print." Click on "Properties" and select "4x6" for the paper size and "Photo Paper" under the paper type. Click "OK" to close the "Properties" window, then click "OK" again to print the photos.
  • Jul 02, 2010 | Brother MFC255CW All-in-One InkJet Printer
    I cant print 6x4 pictures
    make sure you have photo paper in the small tray and the tray is pushed in the whole way. The green light will come on. Load the paper with the shiny side down.
    Jan 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
    Print photo
    all you need to do is load 4x6 on your 4x6 photo tray(the small tray) then pupsh the tray all the way in until the green light on the right lits up then you are all set.
    Oct 22, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Printing photos
    Of course you can use 4x6 photo paper
    you have select the paper size from page setup as 4x6
    and put the paper in the tray after adjusting the tray size
    Dec 27, 2007 | Samsung CLP 300 Laser Printer
    Reprinting photos
    try using a ruler to check if you have the correct paper size.
    open up HP Solution Center verify the printer settings..
    use borderless printing, paper size 4 x 6.
    Dec 27, 2007 | HP Photosmart C6180 All-In-One InkJet...
    MFC-5440CN 4X6 PRINT
    mabey try using windows, not linux, make sure you have driver and other software on CD.
    Jul 21, 2007 | Brother MFC-5440CN All-In-One InkJet...
    Canon i860 InkJet Photo Printer Logo
    79 people viewed this question
    old marine
    old marine
