Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
I need power cords for my monitor
I purchased a dell ultrasharp 1704fpt 17' flat panel lcd monitor and the person who sold it to me did not supply any cords. What do I need to connect monitor to the pc?
    President:
  • 2,992 Answers
The monitor needs a power cord and a signal cable. The power cord is a standard 3-prong detachable cord just like the one on nearly every desktop computer and many other electronic appliances.
The signal cable may be one of two types, depending on your computer's video connector. The monitor has connectors for both VGA (a D-shaped connector with 15 pins) and DVI (a rectangular connector) inputs. You need a cable with whichever type of connector fits your computer.
You should be able to find the power cord at Radio Shack, any of the big office supply places, or retailers who sell computers. The signal cable may be available there as well, or you can order from a number of online vendors.
The monitor also allows you to plug in a USB cable from your computer so you can plug in USB devices like a keyboard or mouse. For that you need the same kind of USB cable you would use to connect a printer.
You can view or download a copy of the monitor user's guide at Dell's site here:
http://support.dell.com/support/edocs/monitors/1704fpt/EN/index.htm
If this solution has been what you need, please take a moment to rate it. Thanks for asking here!
Posted on Feb 21, 2009
I have a Dell ultraSharp 1704FPT 17 in.Flat panel LCD monitor and the power button keeps on blinking green but nothing shows on the display.i tried my cpu on different monitors and it worked well but my...
I think you answered your own question--the computer works well with other monitors, but not this one.
I would suspect that this one is bad.
You might try to do this: Start the computer in safe mode and see if your monitor is reacting to video settings that are beyond it's capability (although if this is the case it should tell you it's out of range).
If it works in safe mode, try resetting the resolution to see if it will work with the new monitor (I seriously doubt that this is the problem).
Oct 07, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704fpt usb ports: how do you find the
you should not need drivers for a usb port is the cable hooked up ? if so they are probably broken
Nov 27, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Falshing green power biutoon.
Verify all cables are secure, try reseating them. If the power led continues to flash, this usually means the power supply in the monitor is bad.
Oct 03, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Need f901 fuse
Here: http://www.mouser.com/ProductDetail/Vishay-Beyschlag/MFU0805FF04000P500/?qs=sGAEpiMZZMseCiJT91fwIrhcnEoxWl66pg5mWW1VsJQ%3d
Sep 12, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Yellow light in power button comes on but tower not will come on ???
Check power cables first, then replace power supply in pc if it still will not power up.
Jun 16, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
No lcd light
Hi...there,
It's seems your backlight inverter/ built-in power supply are busted. Need to replaced a new one or repaired it...
Nov 29, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell UltraSharp 1704FPT 17 in
Remove the stand, look along the bottom edge - you will see two small slots, one either side. Poke something in the slots and wiggle slighly, the corner will come apart - then just pull until all the clips undo.
Sep 07, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT Flat Screen Monitor USB ports
you need to run the usb to your computer first have you done that
May 08, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT Display Problem
It is your inverter/power supply board. Costs around $62.00 with shipping. Not a hard replacement if you have electronic maintenance experience.
Jan 22, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
194 people viewed this question
Alun Cox
