Question about Campbell Hausfeld 2" 18GA Brad Nailer
Driving pin won't reset
I have a mastercraft nailer/stapler ..... the driving pin does not reset after the first staple ..... is there a spring perhaps, in side the housing that has come off? ... can't think what else it might be .... at this point the pin just slides back and forth with no way for it to reset above the next staple in the loading chamber
    President:
  • Campbell Hau... Master
  • 1,388 Answers
The check valve is what causes the pin/driver to return to top of cylinder. To check if it is in place, remove the cylinder from the gun and look for an oring/band installed on a groove. This groove should have vent holes drilled thru the cyl. Holes should be clean. Any oring or rubber band can be used here. Just tight enough to stay in place. Other things to check:
Pin/driver should fit snuglly enough to hold it's own weight in cylinder. If your gun uses a plastic ring, it may be replaced with a rubber oring. Just make sure that the piston travels freely but holds its wieght.
There should be a bumper and a washer in the lower part of the gun. The bumper should not have any cuts or missing pieces and the washer should fit snuggly around the driver blade to prevent air from leaking down thru bottom of gun. If air is leaking down thru bottom, there is less pressure to push driver up. Email if you have more questions, good luck with your repair.
Posted on Feb 23, 2009
Where does the spring go inside a Sear's Craftsman Staple gun & brad nailer?
if the spring popped.. it will pop again
no exploded view for it
@ $20 stapler might be a throw away stapler
you can undo the screws to the housings
keep it as spare parts
Nov 10, 2016 | Tools & Hardware - Others
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
Our staples won't go all the way through . We
You didn't list the make and model of your stapler but if it's not driving the staples flush with the surface here are some possible causes:
1. The wood; If you are driving long staples into hardwood or knotty lumber you may have to use shorter staples to see how they set.
2. Stapler settings; Turning the air pressure up isn't the answer to driving staples deeper, it is only harder on the stapler. Most staplers work in the 90 to 120 psi range. The lower pressure you use the longer your stapler will last. Check/adjust the depth of drive control on the stapler to determine where the top of the staple is driven to.
3. Broke stapler; If it's not driving them to the proper depth but the level they are driven to is consistant, you may have a damaged piston o-ring/seal or the end of the driver is broken off. You'll have to go into the gun or take it to a service center to check these things.
Mar 04, 2012 | Air Tools & Compressors
Bostitch Mlll floor stapler drives a staple only on about every third try.
If the tool sounds like it is firing when its struck but its not driving staples, there may be a problem with the feed magazine. Possibly something stuck in the staple slot keeping them from sliding through. Or possible the pusher spring is weak. This spring feeds the staples into the unit.
Dec 26, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
How to remove staples from bostitch T5 model only to change type of staples
Lift the hinged guard on the front of the stapler and while open use a pencil or similar object to depress the striker (above the staples). This will release the spring catch and the staples will move forward. Use caution and catch the staples as they come out under spring pressure.
Jul 28, 2010 | Stanley Bostitch HP118K 23 Gauge Headless...
Instruction book for Arrow ETF50P staple gun . lost the instructions and can't figure out how to insert the staples in the gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Apr 19, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
How to use Stanely300 Electric Nailer/Stapler
there is a clip and spring at the back and that will release the bar to load the stapler. then after it is plugged in you must put the head down on the surface you want to staple and then press the trigger. you will have to do this for each staple you drive
Nov 12, 2009 | Hand Tools
The spring has come out and we don't know where to put it
The Spring keep the Staples against the Stapler driving tool. Normally there is a metal pad to push against the staples, a rod that goes thru the Spring with a metal latch that locks inside the Stapler.
Jul 01, 2009 | Stanley Staple/Nail Gun Elec
How do the staples stay in place in my stanley 1/4" stapler? They slide back and forth and therefore aren't in place for the stapler to work?
There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to bostitch.com to find the parts you may need
Apr 18, 2009 | Stanley Tools Staple/Brad Nail Gun
Duofast stapler shoots a staple as soon as i plug in the air
I have rebuilt many older Duofast staplers and have seen the problem that you describe. Duofast staplers have twice as many orings as other brands of nailers. Some people say that the nailers are over-engineered. I say that they were built to last a lifetime and need extra care when working on them. Duofast relies on various springs to reset functions or operations. For example there is a spring within the trigger valve that you do not see when you are rebuilding that may be weak and cant overcome the friction of the new orings. That spring resets the trigger after firing. If you replaced all the orings but did not replace any of the springs within the gun, it will take a while for the gun to get back to normal. I use new springs and lube all the parts with silicone lube instead of oil. Silicone lube is sold at Lowes in the plumbing department. It is used to lube orings in faucets. Instead of taking the gun apart, try using a little extra nailer oil in the gun and cycle the gun with-out nails dozens of times to work-in the new orings. If the problem does not go away, take a look at a breakdown and try streaching all the springs just a bit, or make sure that all the springs are in place. Also make sure that the head gasket is in good shape or the oring that seals the headvalve port to the body. Good Luck with your repair and email if you have other questions.
Mar 20, 2009 | Air Tools & Compressors
Campbell Hausfeld 2" 18GA Brad Nailer Logo
683 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
