Question about Coleman 10' X 10' Sundome Tent 9160K101
Hot ground wire on folding camper. Coleman folding camp trailer tail and blinker lights do not work. Hook up to Van and outiside light by door comes on. It appears ground wire is hot.
22yooper
  • 828 Answers
SOURCE: 2001 Coleman Niagara Elite folding
You may have one of two problems; The pilot orifice is very small and allows only a limited flow and any air trapped in the gas supply takes some time to bleed out while you are holding down the pilot button. Or the pilot orifice may be plugged in which case you would have to replace it.
Posted on Jul 10, 2008
SOURCE: coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
Posted on Dec 31, 2008
  • 92 Answers
SOURCE: AC unit wong start unless I spin the blower
you have 2 windings that are in you motor,One winding is the start winding It give the motor its initial boost that gets the fan spinning.The other winding is the run winding and it takes over and keeps the fan running.So it sounds like the motor is bad because the start winding is not giving the boost it needs to start. good luck--Nate
Posted on Jul 15, 2009
  • 13 Answers
SOURCE: coleman bayport camper electrical problems
you would be better obtaining a cheap multimeter and test the continuity of the wiring. Or check the contacts were the bulbs sits. you can use a finger emery board to clean the contacts, hope this is of use.
Posted on Jan 16, 2011
  • 4736 Answers
SOURCE: coleman heater model 5445c700 propane camp heater
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Rich
Posted on Feb 07, 2011
I shorted out my tail light while wiring a trailer hook up and now my 1997 dodge Ram Van will not start
Find the tail light fuses.
They should be under the hood near the battery by the firewall. If not there look under the dash to the left of the driver.
If it's not a fuse, then it's probably a broken hot or ground wire in the wiring to the trailer.
Hope this helps.
Mar 26, 2015 | 1997 Dodge Ram
Ater wiring up for a camper. my 1994 ford 350,tail lights come on when i turn the key on.
Are you sure you tied into the factroy trailer wiring circuit of the truck? It is really hard to mess this up.
Oct 23, 2012 | 1996 Ford Econoline
Hi, we recently bought a 2010 Honda odyssey and ha...
is the trailer attached to the ball on the van?? could be a ground problem,,run a jumper from hitch to trailer see if that works,,
May 21, 2010 | Cars & Trucks
I have an early 90's Starcraft pop up camper. I just went to hook it up to the van and the travel lights (running, brakes, directionals) don't work at all. All lights worked when the camper was stored last...
When you say that you have power up to the camper, do you mean power through the pigtail/wiring harness with the tow vehicle connected?
The trailer harness wiring is the only way to power these exterior camper lights, i.e., through your vehicle. There are no fuses within the trailer for the exterior lights. These lights are only fused from the tow vehicle's fuse box. So either the connections in the trailer harness are open, or they're open at the tow vehicle connection.
Do the turn signals work on the tow vehicle? If yes, then the only other thing to check is the turn signal flasher in your tow vehicle. A heavy duty flasher is recommended.
From the trailer, yellow, white, brown, red, green, is connected to your vehicle backup, ground (frame), right turn signal, left turn signal, running lights, respectively.
The trailer's blue wire is for an electric brake connection to your vehicle.
The trailer's small black wire should connect to the vehicle's hot, 12V lead for the interior lights. The large black wire at the trailer hitch is for charging an RV battery on your trailer, if it's supplied with one. Of all of these wires, only the large, 12 gauge, black wire goes to the 25 amp converter, which is fused, for the inside lights of the camper.
I hope this helps.
Apr 25, 2009 | Sport & Outdoor - Others
Trailer light hook up problem
It sounds like your have may have your brake light and running lights crossed on your wiring harness to the trailer. Good luck and hope this help's
Apr 08, 2009 | 2004 GMC Envoy
2007 Tacoma Tail light problem.
Check the taillamp fuse on the truck. If it is blown, you either have a short in the wiring of the camper, or the 7 pin inverter box on the camper.
Oct 27, 2008 | 2007 Toyota Tacoma
2001 Sportage Trailer wire connections
brown to the tail lights. yellow to left turn signal. green to right turn signal. this is a basic 3 wire hook-up i use all the time w/4wire connectors for all trailers. white wire is not used. ground is established when you hook to the ball.
to find the correct wire to splice to, use a testor (has a clip to the bare wire, and a sharp point to the truck frame). using a needle, push it through a wire to rear light harness. turn on the turn signal. check if the connection is the blinker, testing until you have the blinker wire. the tail lights can be attached to the license plate wire. brakes and blinkers use same wire, so brake lights will work whenever the turn signal is attached.
to be sure everything is working right, have a second person go inside the truck and work the signals, brakes and lights one at a time while you are at the back of the trailer telling what to do.
Oct 24, 2008 | 2001 Kia Sportage
Trailer wiring for 06 GMC Canyon 4x4
exactly what does it do? please explain what happens when you press the brake turn on the light than brake signals ect.....
Aug 13, 2008 | 2006 GMC Canyon
Wiring harness problem
the issue is the trailer, negative or power feed back,check grounds
Jul 24, 2008 | 2002 Ford Windstar Cargo
Trailer Connections
I took the vehicle to Bosch, an electrical expert in Germany.
Jun 28, 2008 | 1997 Ford F150 Regular Cab
Coleman 10' X 10' Sundome Tent 9160K101 Logo
152 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
