Question about GE Monogram ZDWC240NBS Stainless Steel Wine Cooler
I have a GE Monogram Wine cooler model ZDB24AABB cooling fan
I have a GE Monogram Wine cooler model ZDB24AABB . The cooling fan on the back doesn't start sometimes when it should. If I move the unit it starts and works properly for about 3 days. When the fan doesn't start the unit starts to get warm and you can smell it heating up. What controls the fan starting? is it a thermo switch of some kind?
  • GE Master
  • 3,361 Answers
No switch. Fan motor going bad and must be replaced.
Posted on Feb 21, 2009
My GE Monogram Wine Cooler ZDWR24OP does not cool properly. I have the temp set at 51 and it has steadily gone up to 56, 57, now 59. There is some frost on the upper back area inside. I turned it o
Sounds like it is low on refrigerant or not pumping. Either would require a qualified service tech and the repair costs, depending on the price of the cooler, might possibly exceed what you'd want to spend.
Sep 12, 2014 | Refrigerators
GE Refrigerator Model ZDWC240NABS not cooling
if it is a clicking sound maybe it is a relay. try replacing that
Oct 27, 2012 | GE Monogram ZDWC240NBS Stainless Steel...
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
The wine cooler doesn't seem to be cooling light goes on when you open door so pretty sure it has electricity to it?
Can you hear it running? If there is a question, leave the door open and remain there until you hear it start. This may take up to 15 minutes.
What do you have the control on? Wine coolers ar not refrigerators. (White) wine typically served at cellar temp (around 50 to 55 degrees. My friend, please don't tell me you are chilling quality Reds! You are killing them.
Thanks for your interest in FixYa.com
Jan 29, 2011 | GE Monogram ZDWT240PBS Wine Cooler
The wine cooler light works but it does not cool.
so the light tell us that it has power . you need to ck the fan underneath in back and make sure it is running and feel the compressor it runs when the fan does . and you may nees gas in the unit . . so ck the fans / then the compressor see if hot or can you feel it running and then the refergent . and the thermostat down in front . andy of these could cause the no cool problem. mm hope this has helped ..feed back pls ..
Nov 25, 2010 | GE ZDW24Y Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
Brand new out of box and will not cool - after 12 hours - compressor is very hot ?
First question is, are there any fans that are built in that are not running? next is there may be no freon in the unit. Ive seen new stuff from the factory have no freon inside. feel the suction line (the bigger one) from the compressor. It should be cool. The discharge line (smal one) should be hot.
Dec 23, 2007 | GE PWR04FANBB Wine Cooler
GE Monogram ZDWC240NBS Stainless Steel Wine Cooler Logo
459 people viewed this question
Top GE Furniture Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Day Coker
Are you a GE Furniture Expert? Answer questions, earn points and help others
