Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Burner won't light
I have a GE Profile gas stove top and thefront right burner won't light. I can hear the clicking but don"t see a spark.
    President:
  • 2,976 Answers
Take the pot support and the burner cover off and clean all the slots out with a toothpick. Carbon builds up over time and the gas doesn't flow over the spark. Do not light until fully reassembled.
Posted on Feb 21, 2009
    Genius:
  • 2,120 Answers
The gas jet is clogged, clean with a toothpick
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
One of 4 burners doesn't spark/light -- GE JGP979 Cook Top
I am going to assume you hear the "clicking" sound when you try to light the burner.
open the top of the stove. there are four burner. look at the one that is not lighting. use a straighten paper clip open the holes that is directly in-front of the tube that is facing the center of ignitor.
also make sure that the air vent directly behind the knob is fully open.
Mar 30, 2009 | GE 30 in. Profile JGP979 Gas Cooktop
Burners not lighting
You have one or more spark switches defective or a loose wire to the switches.
They are located on each gas valve stem.
Yes they should be replaced for safety.
In the interim you can match light the surface burners.
Feb 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
513 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
