Question about Microsoft Xbox 360 Console
The xbox restarts itself repetadly when it starts
When i turn on the xbox it restarts automaticly and it will keep on restarting before the xbox logo goes to the center of the screen.
  • 27 Answers
This could be do to a bad ROL (ring of lights board) easy to replace and cheap. about 6 bucks on ebay. they even have one's with blue or red lights to give you a cool look to your system. if not this may have to be done....
is what you need to do is open your'e console, their are help video's on U tube for this. Once your is console open and you have the mother board taken out you need to remove the heat sinks which are on top of the chips. just un-snap the x clamps (on the bottom of the motherboard) and take off the heat sinks. unscrew the tabs on the bottom of the heats sinks and take them out. now take one of the heat sinks to a hardware store and find 8 screws about an inch long that screw into the heat sinks, also buy 16 plastic washers and 8 metal washers that fit onto the screws.also trey to find a BUTANE Torch this will save you from the expensive heat guns and work just as good. the last thing you need is Arctic Silver 5 which can be found for 5 bucks on eBay. now once you have this you need to lay your motherboard on a flat inflammable area. light the torch and make sure it is on the LOWEST setting and that the flame is about 3/4 inch long and make a sort on hissing sound. make shure the top of the chips are cleaned with a paper towel of the paste. start with the torch about 3 inches over a chip and keep it moving with a sweeping motion after about 30 seconds start to get close but not to close about an inch an a half away and keep making sweeping and circular movements for about 2 min. do not get to close. now move to the next chip and do the same thing. now after ur done with the chips move the torch away about 3inches and keep heat on both chips for another minute and let them cool for a total of 10 to 15 minutes. once they are cool to the touch clean off the metal parts of the chips with alcohol (I preffer acitone too) make shure they have a mirror like finish and put a very little glob of the artic silver on the metal chips and evenly flaten it out till it covers them evenly, make shure to apply enough! ( i used the side of a allen wrench, its less messy). now on the bottom of both heat sinks, clean them off with acitone or alcohol and scrub them very firmly to get off the grime from the paste. now put one plastic washer on each screw and insert them through the bottom of the holes surrounding the chips flip the mother board over and put the other 8 plastic washers on the screws and on top of these put on the 8 metal washers. then put the heat sinks on and tighten them down. once you put the mother board in the metal casing, plug it in(dont fully essmble it yet) now test out your xbox by pressing the little button on the ring of lights board and let it boot up a usual. If it works then ur done, but if 3 red lights start blinking or two red light start blinking you need to adjust the 8 screws. through the 8 holes in the bottom of the metal casing stick a small screwdriver in there and make shure they are all snug but not to tight and then loosin each one about an 1/8 of a turn till there just a little loose. keep testing and adjusting the screws till it boots up with the green lights.
THIS WILL REPAIR 3RED LIGHTS,FREEZING,NO VIDEO, 2 red LIGHTS. in most cases 1 RED LIGHT will be fixed
GO TO A HAREWARE STORE FIND THE FOLLOWING THINGS IF YOU DONT HAVE THEM
16 platic washers
8 metal washers(make shure all the washers fit snuggly around the screws and are very thin)
8 screws about an inch long that fit heat sinks
Butane blow torch, just a small one will do
small torx wrench kit. big and small flat and phillips head screwdrivers
Posted on Feb 22, 2009
  • Jared Harris Feb 22, 2009
    check to see if this persists if you take off the hard drive and check all connections.
My iphone 6 keeps rebooting, I've already done a hard reset several times and a safari clear history, no good
hi Vardi.
i know you have said you have done a reset but this is all i could find out.
To perform a hard reset, hold the power button and Home button (the circular button below the screen) at the same time until your iPhone screen goes blank and the Apple logo reappears. ... People were amazed when they'd come into the Apple Store and I'd quickly fix their deadiPhone with a hard reset.22 Sep 2017
Why Does My iPhone Keep Restarting? Here's The Fix!
https://www.payetteforward.com/why-does-my-iphone-keep-restarting-heres-the-fix/
Why does my iPhone keep restarting itself?If iPhone iPad Keeps Restarting Randomly. You can restart or force-restart youriPhone iPad to clean all processes, which may help you fix "keeps restarting" issue. To force restart one device, just press and hold both of the "Sleep" and "Home" buttons at the same time for 10 seconds until Apple logo appears on screen.
What do you do when an Iphone keeps turning on and off?To do so go to settings ? Cellular/Mobile ? Turn On/Off Mobile Data. RebootiPhone: To reboot your iPhone, hold the power button and home button simultaneously for a few seconds. The Apple logo will appear on the screen and your iPhone is rebooted.24 Mar 2014SOLVED: My iPhone keeps rebooting/shutting down by itself? - iFixithttps://www.ifixit.com/Answers/.../My+iPhone+keeps+rebooting-shutting+down+by+itse...Search for: What do you do when an Iphone keeps turning on and off?
or go to this link.
iphone 6 keeps rebooting Google Search
Dec 02, 2017 | Hard Computers & Internet
Where is the reset button on my xbox360
I hope this helps:
  • Remove all discs from your console.
  • Turn off your Xbox.
  • Then turn it on using your controller. Press and hold the Guide button until it turns on.
  • While the device is booting, press and hold the Y button + right trigger. The Xbox 360 logo will appears (keep the button pressed).
  • The device will restart and you'll get the Xbox 360 logo again.
  • The display settings are now reset to the defaults.
Mar 13, 2014 | Microsoft Xbox 360 with Kinect
Xbox360 reset code
First of all you must remove all disc from your console.
  • Tested with a single gamepad.
  • Turn off your device.
  • The turn it on using your gampad.Press and hold the Guide button until it turns on.
Dec 24, 2013 | Video Game Consoles & Games
My sumsung sghd780 keeps restarting itself
Restarting when? While booting?
If you have having boot problems and the systemkeeps restarting, then turn off the computer, then hit the power button andimmediately start hitting the F8 key repeatedly until you see SAFE MODE. Scrolldown past Safe Mode and you will see an option to DISABLE AUTOMATIC RESTART.Take the Disable Automatic Restart option.
Mar 30, 2012 | Computers & Internet
Restart
Automatic Restart? Are you trying to Start Automatic Restart or Stop Automatic Restart?
If you have having boot problems and the system keeps restarting, then turn off the computer, then hit the power button and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down past Safe Mode and you will see an option to DISABLE AUTOMATIC RESTART. Take the Disable Automatic Restart option.
Mar 28, 2012 | Computers & Internet
I am having a problem with my computer as it is not starting up properly. I am unable to get to the welcome screen as it keeps restarting automatically. Is there anything that I can do.
A quick F8 right before when you'd normally see the "Windows" logo of it booting will pull up a text menu, use down arrow to get to "Disable Automatic Restart on Failure" and hit enter on it. If it's still restarting automatically, it could be virused or a deeper hardware or driver issue causing the problem.
Sep 09, 2011 | Computers & Internet
Forgot my password
Reset your xbox 360 console
  • First of all you must remove all disc from your console.
  • Oct 08, 2010 | Microsoft Xbox 360 Console
    MY LABTOP KEEPS SHUTING DOWN. I TURN IT ON IT SHUTDOWN AUTOMATICALLY AND THEN RESTARTS.
    Does the laptop POST? does it boot up windows? or do the lights go on.... then off.... then on... etc?
    if it starts booting windows then restarts itself then there is probably a problem with your windows install, it is crashing and that automatically restarts the pc.
    If the lights keep flashing you probably have a hardware failure (motherboard)
    Jun 06, 2008 | Gateway Computers & Internet
    My xbox 360 keeps on restarting
    hit the bution by the on bution and in dack of the controlor
    Mar 20, 2008 | Microsoft Xbox 360 Console
    When turning on screen fades away then restarts automatically
    Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
    Mar 09, 2007 | SanDisk Sansa e260 MP3 Player
    Microsoft Xbox 360 Console Logo
    786 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
