Question about Grundig GF70-600 TV
Fuzzy Speakers Static noise on my T.V when the volume is relatively high
Put a **** in it
Posted on Nov 13, 2010
High pitch noise from speakers
Hello there!
Sometimes High pitching its just that, static on the area, like if you are near a microwave, or near other electronic equipments, but, if the skreetching sound keep going or even if you do nothing it could be a line inside the sound card, or you need to clean the volume botton with special electrical cleaner. other that these, its contacts, or bad cap for the volume board inside.
Good Luck!
Carl
Apr 25, 2017 | Acer Computers & Internet
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
Basically, I've noticed a fairly faint static noise while listening to music at about 30%-40& with the Logitech z-2300's. I dont know if the problem persists when the speakers are any higher because I...
Most speakers I have owned or listened too have a faint buzz or static to them. If you are using a computer turn up the volume on the computer all the way and then you should not have to turn the volume knob on your speakers past 20% that's what i did with mine and they sound fine. If you are using something else like an i pod or something like that make sure you turn the volume on the device all the way up to ensure you don't have to turn the speakers up that high. If that's not your problem then i don't know.
Dec 12, 2010 | Logitech Z-2300 Computer Speakers
As soon as the toshiba a200 boots up there is a loud static noise in the speakers.It does not stop making the noise. The problem started 2 months ago when adding an audio file into powerpoint
you should check the configuration of the microphone and see if the volume is very high which leads to feedback with the speakers and produces the squeak
May 24, 2010 | Toshiba Satellite A200-0ET00X Notebook
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Bose lifestyle 20 static
if you have turned the speakers to a high volume you have to tighten all the screws and bonds that should help
Oct 14, 2007 | Bose Lifestyle 20 System
Noise I don't like
The only real way of telling is a true bench test of the speakers. The speakers should be but on an amp with an adjustable tone generator at o db. The amp. should be hooked up to load resistors with 0 db(.775 milivolts) frequency sweeping hooked up to a ocilliscope to test properly. Anything else would be just a shot in the dark or a quess.
Sep 03, 2006 | Visonik V106S4 Car Subwoofer
Televison & Video Logo
109 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
