Question about DCS 60-10-2 Gas Kitchen Range
Can a DCS 60-10-2 be converted to L.P.?
We have a DCS 60-10-2 in Natural gas and would like to convert it to L.P. gas for installation in another location. Can this be done? Is there a Kit?
Thank you,
Larry Duvall Jr.
  • larry_duvall Feb 22, 2009
    Thank you for the good contact info. Larry
    Novelist:
  • 125 Answers
Hello. Yes it can be converted to LP, the kit part however, not sure. I would suggest contacting the manufacture to see if one is available, and who/where to get it. Here is some info:http://www.dcsappliances.com/customercare/contact-us.cfm
or you could contact a local servicer by checking your phone book, under "restaurant equipment repair".
Hope that helps, and thank you.
Posted on Feb 22, 2009
  • Jim Apr 13, 2009
    Congratulations, and happy to help :)
Is there a conversion kit to convert a DCS FSF 40 fryer from natural gas to propane
If it is natural gas fired, why not use butane? Save all the bother.
Oct 27, 2014 | Kitchen Appliances - Others
Convert from natural gas to lp
You can purchase an LP kit and install it on your burner
Nov 25, 2013 | Magic Chef CYG3004AWW Gas Dryer
DCS RGS slow to preheat
You didn't state whether you used a DCS conversion kit or not. I was able to find conversion instructions for a model similar to yours (not an exact match) but it will give you an idea as to what all is involved.
DCS RGSC 305 Instructions Manual
Dec 14, 2017 | DCS RGU-364GL-N Professional Series 36"...
I bought a dcs fryer at a restaurant auction. I had it installed in my restaurant, and when I got it going flames were shooting out of the back. I had it looked at, but because there is no serial number...
The difference between Natural Gas Set Up and Propane Gas Set Up on Fryers are as follows:
Natural gas burner orifice has larger bore (#52) than Propane Gas burner orifice (#55 or #56).
Gas Valve's spring kit for natural gas has less tension (thinner) than Propane.
You have to order burner orifice ( the quantity depends on the number of burners your fryer has), pilot orifice and Gas Valve Spring Kit for Propane Gas if your fryer is set for Natural Gas or vice versa.
Regards.
Jun 22, 2011 | DCS Kitchen Appliances - Others
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Can't get even flame on burners
Natural gas and Propane operate at different pressures known as WATER COLUMN INCHES and require different jets to work properly.
If you have changed the jets ( installed in the correct direction) and are using a new LP regulator You should be good to go. If you are using the old Nat Gas regulator it just ain't a goin a work
Feb 15, 2010 | Grilling
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Where can I purchase the orifices to convert my DCS FSF-40 fryers from propane to natural gas? Or is there another way?
Contact your gas utility. They are usually very helful and may even do the conversion.
Nov 16, 2009 | DCS FSF-40 Deep Fryer
Convert from lp to natural gas
you need to change the gas regulator (if installed on back of oven),pilot and burner orfice your ready to go.happy new year.
Dec 05, 2007 | Magic Chef CGR3742 Gas Kitchen Range
DCS 60-10-2 Gas Kitchen Range Logo
240 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
