Question about Motorola For MT2000 HT1000 HT6000 GP900 JT1000 GP1200 MOBIUS MTX8000 MTX9000 MTS2000 7.5v 1300mAh NiCd Intrin... 2-Way Radio
Software programming GP900 Motorola - Motorola For MT2000 HT1000 HT6000 GP900 JT1000 GP1200 MOBIUS MTX8000 MTX9000 MTS2000 7.5v 1300mAh NiCd Intrin... 2-Way Radio
MT2000
With so little background or history info I would ask if the battery is fully charged. It could have a battery that is weak. Let the battery wear down completely and recharge it, then try it. Was it was programmed successfully or did someone program it at all? Need more info.
Feb 14, 2012 | Motorola For MT2000 HT1000 HT6000 GP900...
Where can I get an operation manual for an MT2000 free? Moptorola site?
YES. Your are right. Please follow the link below to download you manual.
MT2000 Product Manual
Apart from this, if you required the software for your MT2000, Click Here to download from manufacturer rescources.
Jun 13, 2010 | Motorola For MT2000 HT1000 HT6000 GP900...
How culd i program a mt 2100
Needs Motorola software and RIB box.with programming cable $$ It is a very specialized professional radio for a specific use.
Oct 08, 2009 | Motorola For MT2000 HT1000 HT6000 GP900...
Will the software from a MTS2000 work for a MT2000? if so what do i have to do to make it work
The MTS2000 shares software with the MCS, software package # RVN4176N includes DOS software RVN4097 for the MT2000. (It may be on the same CD, not sure.) You will need to use a "slower" computer, era 1999-2003 to program, due to speed issues.
Disclaimer: Motorola software is proprietary and only offered by Motorola to authorized dealers and entities.
Sep 16, 2009 | Motorola For MT2000 HT1000 HT6000 GP900...
Motorola HT 1000 programming cable
Sorry to let you down, but the cable will only function with the appropriate Motorola software (and possibly a radio interface box (RIB) if the cable type you have requires one.) Software is only available to dealers. If you are needing reprogramming, it is generally available for between $25-$40 US.
Nov 17, 2008 | Motorola For MT2000 HT1000 HT6000 GP900...
Motorola HT 1000
Your radios might need reprogramming. This is done by a Motorola dealer using the appropriate cable and software. The software is not available for end-users. Cost generally is $35-$40 US.
From the information you provided, it is unclear if the radios previously worked together; or if the radios are the same model number. These are facts the dealer would be able to inquire about, and it would help them determine if your radios can talk to one another.
Looking for Motorola HT 1000 manual 68P81079C50-0
6881079C50 is the part number you need. It should be available from any US Motorola dealer for $15-20. (Note: I could not find one posted online.)
Nov 16, 2008 | Motorola For MT2000 HT1000 HT6000 GP900...
My motorola GP900 has problems
Check for a bad antenna, wrong antenna, or no antenna. Switch antennas with a known good unit and see if the problem persists. If this does not solve the problem, you most likely have low transmit power, and the radio needs to be serviced.
Oct 17, 2008 | Radio Communications
Radio Communications Logo
1,280 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
