Question about Amana NAV5800A Top Load Washer
I have a Roper washer which is about 15 years old and it has never run properly because the hot water trickles in so slowly that I can only wash with cold. Can you make a suggestion Thanks Roz
  • Amana Master
  • 3,361 Answers
Make sure the hot water valve is turned on completely.
It is usually the cold water that creeps in because of clogged filter screens in the hoses.
Posted on Feb 21, 2009
My roper washer stop during after the rinse cycle. Is their a reset button.
remove plug from wall is master reset. but its most likely a sensor or controller issue? get a service manual first.
Aug 21, 2015 | Roper Washing Machines
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
Cold water fills very slowly
Possible the INPUT FILTER of the COLD water is clogged or the INLET valve is faulty. check the power from the board.
Jan 02, 2013 | Roper RAS8445KQ Top Load Washer
The cold water just trickles out.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Oct 14, 2010 | Roper RAS8445KQ Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Hot water barely trickles into washing machine
Check the hose at the end where it connects to the washer (the inlet valve unit). There may be a screen there also that needs to be replaced or cleaned. If not then the hot water solenoid valve is probably gunked up with the same type of stuff you found in the filter screen. You may be able to clean it enough to get it to work but replacing it is just as easy and not very expensive. (Even cheaper see if you can salvage one from an old machine at the dump or that someone has left at the curb--the units are very standard across many manufacturers in the tU.S.) Both the hot and cold water valves are in the same unit.
Jul 23, 2009 | Admiral AW22 Top Load Washer
Water trickles slowly into the machine.
Turn off the water.
Switch on the machine and let it try to start filling, that will take the mains pressure off the hose, switch off the machine
Take off the hose at the washer end and check to see how much dirt there is in the small filter inside the inlet solenoid
Most of them pull out for cleaning , be gentle they are nearly all made of plastc and can crack
May 27, 2009 | Roper RAS6233KQ Top Load Washer
Cold water trickles very slowly hot water has plenty of pressure it is a maytag pav2300 how can i fix this problem
1. Check cold water hose for obstructions
2. Check cold water spigot for proper water volume
3. Cold water electronic valve may be failing, easy to replace
Apr 15, 2009 | Maytag PAV2300 Top Load Washer
Water Trickles in When Filling
check the sreens in the hot and cold water valves on the machine make sure there not plugged with rust
Mar 06, 2008 | Roper RAS8445KQ Top Load Washer
Amana NAV5800A Top Load Washer Logo
42 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
