SOURCE: Electric cooktop burner is always on hi when it's on
I just wanted the name of the part and possible sources. Not worth paying $14 for.
I found it else where.
You should give your prices up front, before users spend any time trying to use your site.
SOURCE: Amana gas cooktop clicks when not in use
Take a look at the solutions that have been posted regarding igniters. i suspect a dirty or wet push-down knob. you will see that others have had water/moisture causing problems. drying mights solve it, but it may need a a bit of a clean. keep trying. it must have taken me a couple of hours to solve.
SOURCE: Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
