Question about Akai PT5492S 54" Rear Projection Television
Control panel Lately, the control panel locks up; both manual & remote. To date the problem can be resolved by unplugging & restoring power (reboot). I expect the panel may die completely soon.
  • Richard Godfrey Aug 05, 2007
    Was hoping for some good ideas. I suspect at some point my control panel will fail. At that point the probable fix will probably will be paying a repairman to replace it.
    I was disappointed that my "posting" triggered an immediate solicitation for "enrollment" in a technical service. I strongly suspect that the "technical" opinion will match my own. I, also, strongly suspect that there will be no return of fees!
    Can i say, "scam"!
    Genius:
  • 1,694 Answers
Probable microprocessor IC lock-up.Usually found on signal
PCB==expensive to change out.Sorry--no easy fix on this one.
Posted on Oct 12, 2007
SOURCE:
E-Machine 4115c
Try unplugging, remove battery, plug in, reboot, and run a System File Checker using this procedure: http://support.microsoft.com/kb/929833 AND, test the HDD use this procedure: http://windows.microsoft.com/en-us/windows-vista/check-your-hard-disk-for-errors If this is a recent event do a System Restore to a date before this issue. Or a Factory Restore. Have you cleaned the fan, vents, and heatsink lately? Has there been ANY damage? Drop? Post results
Apr 26, 2013 | Computers & Internet
Wont pass the start menu
Remove ALL media, DVD,CD,USB, Unplug, remove battery, Plug in, reboot and Do a System Restore to a date before this issue. Have you done ANY Updates or Upgrades lately? Post the Compaq Model and the OS you are using.
Mar 02, 2013 | Compaq Computers & Internet
LG 55le5400 remote does not work, front panel does not work, it's stuck on one of the OTA channel. All the lights in the front panel are on. fresh battery on remote. the only way to turn off is un
If you do not have the owner manual either Google the model number for it or contact LG.
This set may have a lock out feature that locks out both the remote and the buttons on the set.
Also if have not tried it--unplug set for a while and power back up which may allow it to reboot.
Jun 10, 2012 | Televison & Video
When I turn on my samsung LN40A530P1F it starts scanning thru and never stops...remote doesn't work when I try to shut it down
If it will not shut down with the remote (manual power also?) it is a microprocessor issue--if have not tried it unplug it and or a box if connected and wait--plug them back to allow them to reboot.
The remote can be tested to see if it is good but will not cause the scanning issue etc.
May 29, 2012 | Samsung LN46B650 46/49.5 in. LCD HDTV
I play 2 beta games on facebook, and lately they stop at the loading screen
Switch On your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jan 04, 2012 | E-Machines eMachines Desktop PC
I am constantly having problems with my interwrite pens. They almost never work when I turn the board on and they often quit working when I am in the middle of a lesson. It is very frustrating.
SYSTEM RESTORE Windows XP: If you are using windows Xp
System Restoring Windows 7:If you are using windows 7
1. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A) Click on the Recovery icon.
B) Click on the Open System Restore button.
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time'
A) Click on the Next button
Now you will find a window with Dates, Description and Type,
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
Sep 15, 2011 | Computers & Internet
My keypad doesnt work even my audio sounds doesnt work properly.
If you have Windows XP do the following steps:
If you have Windows 7 do the following steps:
Sep 13, 2011 | Acer Aspire One PC Notebook
Can not open emails
If you were able to open emails earlier then this will work.
If you are using Windows XP
Let windows boot and log in to windows.
If you are using Windows 7
Please let me know incase if you find any difficulty or any issues
Aug 05, 2011 | Computers & Internet
Does the RCA TV Model G27400WK, Serial No.234550152 have a reset button and where would it be located?
try these steps
On occasion, an RCA television may need to have certain options reset in order to restore default settings. Software resets, such as resetting the Picture Control, the Parental Control lock and the Wake-Up Timer, can easily be restored to the default settings by accessing the settings menu via the remote control. A Hard Reset is recommended if there are hardware problems with the TV, such as a loss of picture or if the TV isn't turning on properly.
if that doesn't work try these steps
  • Unplug the TV's power cord from the electrical outlet.
  • Wait 5 minutes.
  • Plug the TV's electrical cord back into the electrical outlet. If this does not resolve the problem contact RCA Customer Support or a local technician store
  • Jan 04, 2011 | Televison & Video
    Lg will not respond to remote.
    Does it work without remote OK.
    You have to go to service mode menu and adjust. Only service center can help you.
    Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
    Akai PT5492S 54" Rear Projection Television Logo
    Top Akai Televison & Video Experts
    Jaime Hernandez
    KISHORE DESHPANDE
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
