Question about Whirlpool ED2NHGXM Side by Side Refrigerator
Noisy refrigerator When the motor is running, the refrigerator is very noisy. I thought cleaning the coils underneath would help solve this problem, but it did not lessen the noise.
3 Suggested Answers
  • 1462 Answers
SOURCE: Hi I have an Australian
could be you need a new compressor but also check the pipework is not vibrating - if so, a bit of careful bending usually does the trick
Posted on Sep 30, 2008
  • 31 Answers
SOURCE: motor running a lot
9360gabbs,  The significant thing that you list is... it is louder than usual.  You indicate that you have cleaned the coils under refrigerator.  Try and roll the refrigerator out from its normal location so you can get behind it.  Remove the cardboard or metal cover across the bottom area of the refrigerator.  Check and see that the fan next to the compressor is running and that the blades are clean from dust, etc. Sometimes the condenser fan dies and must be replaced sometimes the blades are covered in dust, etc and causes a decreased volume of air to be moved by the fan.  Make sure the entire area is clean from dust, etc.  Be sure to replace the rear cover that was removed.  Very important!  Hopes this helps you! HandyHenry
Posted on Feb 07, 2009
Amana refrigerator TR25S5W - noisy, running too much
Remove the lower access panel on the back of the unit and clean the coils.
Nov 19, 2012 | Refrigerators
Our ice maker is pouring water down the inside of our side by side freezer. We have cleaned out the infrared and thought we turned off the water
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 14, 2011 | Whirlpool Refrigerators
Hi, We have a ge refrigerator gsh25sgpa-ss. Water is leaking down the back of the inside of the freezer. We have replaced the filter and the water valve, any thoughts?
Leo Ponder
imufo2
Aug 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
I have water pooling in the fridge section of my Proline fridge freezer. There is no visible drainage channel that I thought might be blocked. HELP PLEASE!
If the drain is clogged with Ice or ? it overflows into the ref.
Leo Ponder
imufo2
Jul 29, 2011 | Refrigerators
Inconsistent cooling, no ice, noisy fan motor.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Feb 25, 2011 | Viking DFSB483 Side by Side Refrigerator
GE side by side gss23qg gss23qs: Freezer is not working, building up frost, ans is noisy.
If you hear the compressor (underneath the refrigerator) running okay, you need to check around the compressor and see if the compressor fan is turning. If this fan does not turn, heat is not removed from the refrigerant coils as it should be. This greatly lessens the cooling ability of the system.
If this fan is not turning, you will have to replace the fan motor.
Oct 15, 2009 | Refrigerators
Motor runs, but freezer and fridge are warm
The cooling coil/evaporator might not be defrosting.
This could be caused by a defective defrost timer or the defrost heater is not working. Also make sure it is clean underneath the refrigerator and the condenser fan next to the coil in running
Oct 10, 2009 | GE GSL25JFPBS Side by Side Refrigerator
My sub-zero 695 motor keeps running, very noisy..
If it is one with the compressor on top . Check the coils up top . You may find that they need cleaning because it sound like it's unable to cool enough to satisfy the thermostat therefore it runs all the time trying to.
Please rate solution
Aug 25, 2009 | Sub-Zero 695/S Side by Side Refrigerator
Noisy frig
it could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
May 12, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Whirlpool ED2NHGXM Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
