Question about Zyxel P660HW-D1 Router
I have put a password in my router but cant remeber it, so now i cant get in my router to open ports for my ps3.. any ideas
    Scholar:
  • 61 Answers
I take it that you put in your own password - if that is the case then the simplest way of doing this is to reset the router to it's factory settings- usually a pin sized hole on one of the sides which you will need to push in for 30 seconds & then reboot and put in your relevant details. Obviously you need to make a note of your ISP's username & password.
Posted on Feb 26, 2009
I cannot get my ps3 game to work. it says to consult my routers user manual to enable the setting in the games booklet. i cant because the manual has been lost. it requires a UDP port 9301. and i need to...
You'll need to setup port forwarding on your router.
From a computer use an internet browser such as Internet Explorer.
Assuming the router is using default settings.
1) In the address bar type in 192.168.1.1
2) You'll be asked for a username and password. Username is 'admin' and the password is 'password', no quotations.
3) Click on 'Port Forwarding / Port Triggering' on the left side bar.
4) Click on the Port Forwarding radio button.
5) Click the 'Add Custom Service' button.
6) For Service Name call it something meaningful, such as 'PS3.
7) For Service Type choose 'TCP/UDP'.
8) For starting port and ending port use '9301'.
9) For server IP use the IP address of the PS3, you can get this in the PS3 menu under Network Settings.
10) Click Apply
UPnP is supported by your router. On the left side bar, click 'UPnP'.
Feb 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I have a ps3 and an xbox 360...when I have my nat type on moderate then i can sign on both of them no problem but have a time trying to connect to some other of my friends. when I make my nat type open I...
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Jan 06, 2011 | Arris SURFboard SBG900 Wireless Router...
Cant connect to my wii or ps3 with belkin g F5D7234-4 v4 how can i reset and what settings should i put in?
Hi Friend,
To Connect to Wii or to the PS3,we have to open the Open numbers in the router.
So please get the port numbers from the Wii and PS3 Vendor.Once you have got the Port numbers we will be able to open the ports and then you will be able to connect
Regards,
Aysaam
Jun 09, 2010 | Belkin Computers & Internet
I cant remeber the password to my network, that i put on my router
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Apr 17, 2010 | ASUS (SL1000) Router
My PS3 and my Belkin trying to get wireless
*its simple jus get the port number for the ps3 u can get it from ps3 vendor *once u get it login to the router set up page using a computer AS * open any browser type 192.168.2.1 in address bar * on left hand side click on the virtual servers( password -- leave it blank ) * enter the port numbers only for one ip address only for example 192.168.2.10 for all the port numbers. * then apply changes * then go to ps3 assign a static ip address in ps3 for the ip address the one which u opened the ports for (ex 192.168.2.10) * it will definitely work
Apr 13, 2010 | Belkin (F5D7230-4) Router (587009)
Ps 3 linksys 160n problem
Hi Friend,
In order to use PS3 we need to open few ports. Kindly follow the steps:
1.Open the internet explorer and type 192.168.1.1 and hit enter.
2. If you have not changed the default password of the router then kindly leave blank the username box and in the password box type admin and hot enter.
3.In the setup page click Application and Gaming
4. Under that click Port Range Forwarding.
Below are the port numbers which we need to open for PS3
TCP:
80
443
5223
UDP:
3478
3479
3658
Now please type these port number in start and end port. Please make sure start and end port has to be the same.
First enter the TCP ports in first three boxes and then UDP ports in next three boxes.
Save the settings and turn off the router for 10 seconds and restart again.
Enjoy.
Regards
Chiranjeet
Mar 15, 2010 | Linksys WRT160N Wireless Router
Open port 80
To open a port on a router involves several steps.
1) Log into your router from your browser, this is generally at address 192.168.1.1
2) Type in your username and password (this varies from vendor to vendor)
3) Once logged in, go to the Advanced Tab, and then click on Gaming on the side menu.
4) Under the Add Game Rule, put the name, IP address can be left blank, and then set ports to open to 80.
5) Save changes.
Dec 03, 2009 | D-Link GamerLounge DGL-4300 Router...
Ps3 nat type 3
In order to achieve NAT 2, you are going to have to set your PS3 to a static IP address and forward ports on your router.
detailed instructions on how to do this and configure your ps3 can be found here:
http://www.pregamelobby.com/forum/sony-reviews-tips/5618-how-get-type-2-open-nat-your-ps3.html
In order to get into your router settings, go to 192.168.0.1 OR www.routerlogin.net (the router sets up its own DNS) and putting in your username and password. If you have not set up a password, the default username and password for this router is "admin"/"password". Follow the instructions in the page I posted once you are logged into the router's webmin.
Hope this helps!
Jul 15, 2008 | NetGear WGR614 Wireless Router
We do not know our password for the f5d7230 wireless router and cant connect our ps3 to it. Im trying to find a WEP code to input on the ps3. Belkins online manual suggests i need to reset the router to...
Hiya, when you go to your router homepage, normally an address like 192.168.2.1 for most belkins, there will be a security tab, if you look at the wep settings it should give you what the wep key is, if not you can generate a new one and put it into your pc's and ps3,
Your password however if not changed from original will be blank just hit the submit button,
Also there should be a reset button in the casing of the router, this will reset it to factory where password will be blank so hit the submit button, hope this helps
Apr 07, 2008 | Belkin (F5D7230-4) Router (587009)
Zyxel P660HW-D1 Router Logo
119 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
