I need the ssid name and wep key/wpa passphrase to add a hp printer to the wireless connection
  • calene_chew May 02, 2009
    I have the same problem and you suggest that I go to http://192.168.1.1/ and I did but I can't get on to that page. Please help.
    Scholar:
  • 134 Answers
The SSID and WPA passphrase is in your router, this article explains in detail what all this is : http://www.cas411.com/ShowArticle.aspx?ID=68
just type the ssid and WPA key stored in your router in your D-Link print server. Let me know how that go and I can help you some more,
Alex
Posted on Feb 22, 2009
How do i get a pass phrase for my hp photosmart pluse
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops, wireless printer and orcomputers with these router's wireless settings. Then the laptops, wireless printer and desktopcomputers can communicate with your wireless router.
Jul 23, 2011 | Office Equipment & Supplies
Teele27@comcast.netHow do I turn on the wireless connection on my HP Photsmart C6300 All-in-One series printer/copier?
Make sure you know the SSID or 'name' of your home wireless network as well as the WEP or WPA password to connect to your network before you begin.
1) Press the Setup button on the HP All-in-One. It has a wrench on it. 2) Continue pressing until Network is highlighted, and then press OK . 3) The Network Menu appears. 4) Press until Wireless Setup Wizard is highlighted, and then press OK . In a few moments, a list of detected networks appears on the display. The network with the strongest signal appears first.
Do one of the following: 5) Press the down arrow key to highlight the name of the network that you wrote down earlier. Then press OK. 6) If your network uses security, a prompt appears for the WEP key or WPA passphrase. Both are case sensitive. Use the visual keyboard to enter the WEP key or WPA passphrase, as requested. Note : If your router uses 4 WEP keys, make sure you use the first one. 7) Follow the prompts on the display to complete the network setup. 8) Then if you haven't already done so, install your software.
That should do the trick! Hope this helps!
Jun 20, 2011 | HP Office Equipment & Supplies
I cannot find information I need to connect to my wireless hp printer I need wpa key or wep passphrase
When you installed your wireless router, you should have configured its wireless interface:
* set an SSID -- the "name" of your network
* set an encryption-level -- hint: use 'WPA' or 'WPA2'
* set a password or pass-phrase for your network
Enter the SSID/password on your HP printer, to connect it to your router.
Apr 22, 2011 | HP Computers & Internet
On my HP photosmart how do I find my WPA Passphrase. I have a Nexxt solutions wireless-N broadband router and Cable & Wireless TP Link, routers. I live in Panama, Central America
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers can communicatewith your wireless router.
Apr 15, 2011 | HP Photosmart C6180 All-In-One InkJet...
Suddenly today after working for a couple of years all the lights are on solid and my wireless laptops can not find the router
To connect to your wireless network using Vista's WLAN Autoconfig, follow these steps:
Step 1:
Right-click this icon 5449-001.png at the bottom-right corner of the screen and select Connect to a network.
Step 2:
Select your Wireless Network Name or SSID then click Connect.
NOTE:
If the wireless network name or your SSID is not listed, the SSID Broadcast on the router might be disabled. For instructions on how to connect to the wireless network with the SSID broadcast being disabled, click here.
If the computer is not detecting any signal or is not seeing any wireless network, change the channel of the router. For instructions, click here.
If WEP/WPA is enabled on the router:
Step 3:
Enter your wireless network WEP/WPA Key on the field provided then click Connect.
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
NOTE: Make sure Display characters is checked, to display the WEP/WPA key used by the router. You can get the passphrase or network key from the encryption that has been generated (if using WEP network security) from the router's web-based setup page. If you're using WPA network security, the network key is the key for passphrase.
Make sure you enter the wireless network's WEP or WPA key not the Passphrase.
It is also possible to make a wireless connection even if the wireless security is disabled on your router. If you don't see any network SSID from your network list, make sure your wireless adapter/device is ON and your router is in good condition. If your router shows any unstable occurrence, click here.
Related Article:
Configuring File and Printer Sharing Unable to connect to a wireless network using WEP in Windows Vista Windows Vista Articles Listing Encountering Difficulty Connecting a Wireless Computer/s to the Internet when Connected to a Linksys Router Setting-Up the Wireless Settings on a Router Assigning a Static IP Address on a Wired Computer
Nov 06, 2010 | Linksys WRT300N Wireless Router
I need the WEP key WPA passphrase so i can connect wirelesly to my computer
This Utility program from HP will help you locate few details on your network
This Utility program will help you locate few details of your network like,
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly.
Nov 04, 2010 | HP Photosmart Premium C309A All-In-One...
Can't connect the artisan 800 to our wireless network
To add the printer to your wireless network, you need to know the name (SSID)
of your wireless network. If it has security enabled, you also need to know the
WEP key or passphrase. Write down the SSID and WEP key or passphrase below:
■ Network name (SSID): _________________________________________
■ WEP key or passphrase: _________________________________________
Note:
If the WEP key is either 5 or 13 characters, it’s ASCII. If the WEP key is either 10 or 26
characters, it’s hexadecimal. The default WEP key is usually 1.
If your passphrase contains upper- or lowercase letters, be sure to note it correctly.
The printer supports the following wireless security modes: WEP 64, WEP 128, and
WPA-PSK.
If you don’t know your wireless network name (SSID) or WEP key or passphrase,
contact the person who set up your wireless network before you begin.
Insert the printer software CD.
2. Windows Vista®: If you see the AutoPlay window, click Run Epsetup.exe.
When you see the User Account Control screen, click Continue.
Windows® XP: When you see the Software installation screen, continue with
step 3.
Mac OS® X: Double-click the icon.
3. Click Install.
1.Make sure that the printer is turned on.
2. When you see the FireWall Warning screen, click Next.
3.Make sure you connected the Ethernet cable
Oct 09, 2009 | Epson Artisan 800 All-In-One InkJet...
Finding ssid and wpa to set up my C4380 seris wireless printer
The SSID is your network name.
The WEP or WPA is the password to get onto the network. Think of the router as the doorman. The printer needs to get into the club so it needs the password otherwise it can't get access.
The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with your router to see how to access this information. Some routers provide more than one WEP key. Use the first WEP key if this is the case.
Aug 15, 2008 | HP Photosmart C6180 All-In-One InkJet...
I have a laptop run Vesta trying to set wireless connection to HP Potosmart C4385 print using ad hoc network setup. When selecting Ad Hoc connection in the printer setup it saids it can not find it or...
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information Follow the procedure below before obtaining your wireless network:
  1. Obtain your network SSID and WEP. To simplify this process, press the Wireless button on the all-in-one, and select Restore Network Defaults . This turns wireless off and sets the all-in-one's SSID to hpsetup .
  2. Press the Wireless button to turn wireless back on. Look for hpsetup when you select your network.
  3. Make sure that wireless is enabled on the all-in-one.
  4. Make sure that the computer that will be using the all-in-one has access to the router/access point.
You will need the following to set up the product on a wireless network:
  • A wireless 802.11 network that includes a wireless access point.
  • A desktop computer or laptop with wireless networking support or a network interface card (NIC).
  • Broadband Internet access is required for some features of the HP software to function. Cable Internet or DSL are examples of Broadband Internet access. NOTE: If you connect the unit on a wireless network that has Internet access, HP recommends that you use a wireless router (access point or base station) that uses Dynamic Host Configuration Protocol (DHCP).
  • The network name, or Service Set Identifier (SSID). NOTE: The SSID is obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.
  • The Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase, if needed. CAUTION: To prevent other users from accessing your wireless network, HP strongly recommends using a password or passphrase and a unique SSID to your access point. Your access point might have been shipped with a default SSID, which can be accessed by other users using the same default SSID. For more information on how to change the SSID, see the documentation that came with your access point. NOTE: The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.Some access points provide more than one WEP key. Use the first WEP key (index 1) when setting up the wireless network.
  • If the network is set up with an Apple AirPort base station and you are using a password instead of WEP HEX or WEP ASCII to access this network, you need to get the equivalent WEP key. See the documentation that came with the Apple AirPort base station for more information.
  • If IP address filtering is set up, verify that the unit address is listed.
  • If MAC address filtering is set up, verify that the unit address is listed. NOTE: HP cannot set up or change the SSID, WEP key or WPA passphrase. This information is required before connecting the HP All-in-One to the wireless network.
Step two: Connect to an integrated wireless WLAN 802.11 network Follow the procedure to connect the unit to the wireless infrastructure network:
  1. Insert the software CD.
  2. Click Install .
  3. Click Next on the Please Allow All HP Install Wizard Processes screen.
  4. Select Easy Install on the Choose Easy Install or Advanced Install screen.
  5. Select Through the Network on the Connection Type screen. Figure 2: Connection Type screen c01160788.jpg
  6. When it doesn’t find your device, click Next . Figure 3: Using Network Setup c01164746.jpg
  7. Plug in your device via USB (it will tell you when to disconnect later). Figure 4: Making a connection to your all-in-one c01160790.jpg
  8. Select your network from the list, and click Next . Figure 5: Wireless Network Setup c01160791.jpg
  9. Enter your WEP key (if applicable). Figure 6: Specifying your network security settings c01160792.jpg
  10. Once it has completed connecting to the network, click Next . Figure 7: Network connecting completed c01160793.jpg
  11. Disconnect the USB cable from the computer and the All-in-One . Figure 8: Disconnecting the USB cable c01160794.jpg
  12. Click Finish to complete the software installation process. Figure 9: Software installation complete c01160795.jpg
Aug 04, 2008 | HP Office Equipment & Supplies
Can't hook up wireless printer need ssid and web key/wpa
May 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Computers & Internet Logo
1,249 people viewed this question
David Payne
David Payne
