Question about Acer Aspire 5100 Notebook
Computer screen dont come on
Turn on computer and screen dont come on. Seems like goes right into idle?
    Problem Solver:
  • 16 Answers
Just check whether monitor connection is available or not?? if everyything is fine then format it
Posted on Feb 21, 2009
Monitor distorts colors and goes out of sync horizontally after 15 min
they dont last forever... time for replacement as most are not user-serviceable..
Mar 08, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
The light goes off the monitor and it dont turn on when i turn the computer on.
Are you saying when you end up holding the button on the side of the monitor so that the screen turns on solves the problem? more info could help!
Jan 31, 2014 | Gateway LP2207 LCD Monitor
My sister gave me a Compaq evo computer. When i turn it on it goes right to a screen that says Power-on password with a picture of a key. She doesn't know what the password was and it doesn't let...
It seems to be BIOS password, if you don't remember or don't have the BIOS password you have to reset the password by opening your CPU cover and removing the CMOS coin battery, this will reset the BIOS password but dont forget to return back the battery and start using your PC.
Regards,
JJ
May 15, 2011 | Compaq Evo D500 PC Desktop
Hi, I have a ViewSonic VP201b monitor that has a problem.... It seems that it wont turn on (BLACK SCREEN *NOTHING*). The yellow light goes on when idle, but when it's not idle the green light isn't...
Get a working monitor and turn on the computer. Then swap the monitor with VP201b.
Get a flash light closer to the screen to see whether you can see the desktop screen image. Yes? Then it is your backlight inverter.
Find a Youtube video to show you how to open the cover. Then look for any sign of broken capacitor(s). Replace them and then test your monitor. If all capacitors are okay, it is one of your FUSES. There are 2 tiny surface mount fuses ("FN" type). You can short the two ends to test it before removing them. Often only one of them is broken. Replace it and the monitor shall be okay now.
May 12, 2017 | ViewSonic VP201b 20.1" LCD Monitor
There is a humming sound coming from the front end of my 1999 oldmobile alero. Only happens when the car is moving. I dont hear itat idle or even when pushing the gas at idle. could it be my transmission...
Hello! If the humming noise is speed related(gets louder as vehicle speed increases)check front wheel bearings. If the noise goes away when turning one way or the other then it will most likely be in the front wheel bearing. If you turn the wheel(while moving)to the right and the noise goes away it is on the right side. If you turn the wheel to the left and the noise goes away its on the left side. Hope this information helps!
Sep 13, 2009 | 1999 Oldsmobile Alero
My screen only displays after 4 /5 hrs
Try a different screensaver.
Also look in the display properties by simply right clicking the desktop and clicking properties.
Then locate power management.
the initial seems to be a bad screensaver judging by the 20 minutes, but the 4-5 hours seems to be a sleep mode that bypasses the screensaver issue.
Jul 23, 2009 | Computers & Internet
Engine light comes on when i open up throttle
You will have to get a service tech to attach a scanner and read the trouble codes. They should be stored in the computer memory. It should give you a starting place to diagnose the problem.
Jun 01, 2009 | 2008 Harley Davidson FLHX Street Glide
Dell monitor
Sounds like there is a heat related problem. Probably a bad solder joint somewhere. Could be hard to track and would probably cost you more money to repair and it does to purchase a replacement monitor. 17" LCDs go for around $150 these days.
Oct 28, 2008 | Dell Dimension 3000 PC Desktop
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
