Question about Bosch Axxis WFL 2060 Front Load Washer
Wash produces rust marks on clothes though the drum is clean
  • Anonymous Apr 20, 2009
    rust stains on clothes
Probably not recommended by manufacturer but occassionally do an empty wash with bleach.
Posted on Feb 21, 2009
How to stop brown **** marks from washing machine
too many cloth at once and need to clean the glass and seal alot
Aug 11, 2014 | Washing Machines
Dryer is leaving brown marks on clothes. it is either a burn mark or they are getting caught between dryer drum and shell, not the door
I had the same problem. Unfortunately, it is caused by a rusting drum edges, if you can believe it. My dryer was only 6 years old when this problem occured. There are felt gaskets on the front and back of the drums where it contacts and rotates on the frame of the dryer. You can take a white cloth and run it around the rim of the front and back of the drum and I suspect you will end up with some discoloration on the cloth. I had these felt gaskets replaced, but that is only a temp solution. When the drum is taken out and the old felt gaskets are removed, you can clean the edges of the drum and get a lot of rust/brown off the drum. New gaskets are only a temp fix. I did it about 1 1/2 yr ago, and I think the problem is starting again. Probably time for a new dryer or time to pull the drum and clean it. New drum probably cost prohibitive if you can get one. What a bunch of **** for a 7 1/2 old dryer. Next dryer will have a stainless steel drum. Hope this explanation helps you with your problem.
Steve
Mar 29, 2010 | Amana ALG331RAW Gas Dryer
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
I have been getting brown streaks after drying clothes in my whirlpool dryer. they are about an inch long. My dryer is about 12 years old. Is it worth getting new drum seals or ghetting a new dryer?? (...
Try cleaning the entire air vent system of lint first including the exit vent panel (to the outside air). Remove the lint screen and wash it in detergent and hot water. The brown streaks are probably scorch marks rather than oil or grease entering the drum. Good air movement is essential to holding the drying temperature down. Hope this saves that old Whirlpool for another decade!
Sep 23, 2009 | Dryers
WHY IS THERE RUST IN MY WASH MACHINE DRUM
Hi
Thanks for using FixYa. Take out the clothes immediately after the washer stops spinning. Also clean the tub with a rust remover. This issue occurs due to bad drum bearing and it may be grease rather than rust. Although the tub is metal with porcelain coating and it wears around the edge of the holes first, leaving metal without porcelain. On spinning the centrifugal force pushes the clothes against the basket and some water sneaks into the holes. Due to this you may see the rust on clothes. If still the issue persists, then the tub is required to be replaced to resolve the issue. Please do rate the solution and revert for further assistance. Thanks Rylee
Sep 18, 2009 | Kenmore 24032\24036 Top Load Washer
Rust in Kenmore washed clothes
Sounds like you have a bad drum bearing. I would guess that it's grees rather than rust although it will look like rust.
Please rate solution if helpful
Aug 23, 2009 | Kenmore 24032\24036 Top Load Washer
Brown streaks on clothes
you need to install a filtering system on the water supply.
Jul 26, 2009 | Washing Machines
Hi. I have a bosche front loader. At the moment when I was white clothing/ sheets i am getting brown/ orange stains - they sometimes seem like soap buildup marks but more recently seem like scorch marks...
If,like most people,you are washing at 30-40c there may be a scum build up between the drums.This can be cured by doing several 90c washes to clean it out.Bosch themselves call this a maintenance wash.
Mar 19, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Clothes dryer brown marks problem
if that mark is comming from the dryer .the drum has a rust. and you cant paint it or the seal of the drum is bad that seal is around the drum.
Feb 18, 2008 | Whirlpool LTE6234D Top Load Stacked...
Bosch Axxis WFL 2060 Front Load Washer Logo
145 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
