Question about Kenmore 98702 Stacked Washer/Dryer
Balancing problem Frigidaire stackable front load washer/dryer
Frigidaire stackable front load washer/dryer combo. Washer not balanced and vibrates excessively, out of level, moves around too much therfore losing efficiency of spinning cycle. Afraid it will damage washer or counter top. It is located on the second floor off of our bedroom above our kitchen on a vinyl floor in a corner that is structurally sound. Floor not level. Unit has one inch side to side distance between outside wall and counter top. Should I just rebalance it using the levelling legs or is there some way of fastening it to the wall or floor or counter to reduce vibration etc...or should it be fastened. Looking for a permanent solution.
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
LG stackable off balance
Open the machine covers and check the tub/motor shock absorbers or dampers for condition. Best to change all if one is faulty.
Apr 11, 2014 | LG Front Load Washer & Electric Dryer...
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Washer makes loud vibrating noise when spinning. GE stackable washer dryer
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion........
Jul 19, 2009 | Washing Machines
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore 98702 Stacked Washer/Dryer Logo
511 people viewed this question
Sal De
fordexpert
Robert Rankin
