Question about Acer Aspire 5600 Series 5630-6951 Laptop
Turn on computer and screen wont come on computer goes into idle?
  • 2 more comments
  • bwhardwood Feb 23, 2009
    I tried a external screen and that screen goes black as well
    Im not sure if it works properly or not due to the fact I cant see anything. Has good power sorce and I can here it start and run and stays at idle with black screen. When I plugged in external screen it made that screen black and shut down. Is it possible it a virus? Is all my pictures and data going to be lost? Please help
  • RescueTechLA
    RescueTechLA May 11, 2010
    Does it seem to be working correctly otherwise, minus the black screen of course?
    What have you tried besides the external monitor, so far?
  • RescueTechLA
    When you turn it on, do you get any display at all? Can you see the Acer logo? Try hooking it up to an external monitor if you have got one.
    Problem Solver:
  • 7 Answers
ACER PICTURE PROBLEM – MY SOLUTION
I had a similar problem, but I got a picture before it broke up and went off. The screen was backlit, but no video (screen was receiving some power).
The LCD needs a very stable voltage to work, this is provided through the LCD connector ribbon. In my case the ribbon was damaged and replaced it.
I have had no problem since.
I discovered this through trial and error; I first changed my transformer power supply and then the video inverter card.
You may find the link below helpful as it contains articles that photographically show you how to open the laptop for repairs.
http://www.insidemylaptop.com/category/1-acer-laptops/
Hope this helps. (Please rate my advice)
Posted on Feb 23, 2009
    President:
  • 2,653 Answers
It's probably the motherboard then. Your data will be fine, that's a separate portion of the laptop. You'll have to have the computer serviced by a local repair shop, they'll probably say the same thing, motherboard. Your data can be extracted a number of ways but the easiest is to just put it into an external enclosure and then extract the files to another computer.
If you're computer is less than a year old then it's covered under Acer's warranty. If not, then it's probably not worth fixing, but that all depends on you.
Were you using XP or Vista?
p.s. Please don't forget to rate my solution. Thanks!
  • RescueTechLA
    RescueTechLA Feb 23, 2009
    p.s.s. The higher the better :)
Rough idle wont idle
Hi, try to clean your Idle control valve, maf sensor, fuel filter and most important1 clean throtle body, try that to start, c how you go.
Aug 26, 2013 | 1983 Toyota Pickup
Hi, I have a ViewSonic VP201b monitor that has a problem.... It seems that it wont turn on (BLACK SCREEN *NOTHING*). The yellow light goes on when idle, but when it's not idle the green light isn't...
Get a working monitor and turn on the computer. Then swap the monitor with VP201b.
Get a flash light closer to the screen to see whether you can see the desktop screen image. Yes? Then it is your backlight inverter.
Find a Youtube video to show you how to open the cover. Then look for any sign of broken capacitor(s). Replace them and then test your monitor. If all capacitors are okay, it is one of your FUSES. There are 2 tiny surface mount fuses ("FN" type). You can short the two ends to test it before removing them. Often only one of them is broken. Replace it and the monitor shall be okay now.
May 12, 2017 | ViewSonic VP201b 20.1" LCD Monitor
The screen on my macbook pro keeps turning off instantaniously. The laptop its self is still on, though the screen just goes black.
I think your macbook is running on power save mode. This will turn your screen black (off) after few minutes of no interaction with the computer or if your PC is on idle.
Oct 10, 2010 | Computers & Internet
It wont turn on
download and install the zune software in your computer and update the player. That will fix it.
Aug 15, 2009 | Microsoft Zune JS8-00001 Digital Media...
Computer screen dont come on
just check whether monitor connection is available or not?? if everyything is fine then format it
Feb 21, 2009 | Acer Aspire 5100 Notebook
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Sanyo 6600 fully charged battery but wont turn on
just simply take the battery out and the phone will shut off. You will not lose any contacts or other memory as long as the phone is on idle
Aug 01, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Compaq presario C700 note book wont turn on
if you ask your vendor from whom you have bye they will rectify the problem without any fees
Jun 28, 2008 | Computers & Internet
Acer Aspire 5600 Series 5630-6951 Laptop Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
