Question about Marantz SR-4200 Receiver
Marantz SR4200 Subwoofer Not Working
I've had my Marantz SR4200 Amp for years now and have only recently tried to connect a brand new subwoofer (Eltax Liberty S+) for the first time. I cannot get any output from the subwoofer at all. I have connected using the manual and changed all the appropriate settings on the Amp so that subwoofer is on etc. but nothing. I've connected the new sub to my PC sound system which had an existing sub (broken) and it works fine. I'm concious that I may need a special cable? or that it might just be a fault subwoofer port on the Amp? Any advice would be appreciated, thank you.
SOURCE: very low ouput from subwoofer preout
Onkyo to Onkyo, sub/receiver, problem fixed by inceasing volume on receiver. Seems the sub audio input does not pick up LF's below a certain output level from the receiver. So, guess I have to live with that. I only hope my nieghbor in the apartment below me can too!
Posted on Apr 29, 2008
SOURCE: Subwoofer shutdown
I'm having the same issue as pdoug: Sub rumbles in test mode, doesn't produce sound otherwise. Which makes me suspect it's the receiver itself -- the filter (or whatever) it is that should be separating the bass signal and sending it to the sub is not working. At least that's my guess.
Either way... this sucks.
Posted on Nov 01, 2008
  • 17 Answers
SOURCE: No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Posted on Dec 16, 2008
  • 118 Answers
SOURCE: cannot get jamo 250 subwoofer to work via marantz
hdmi has digital audio in it. no need for optical from same device.
check menu settings in receiver to activate sub, set crossover point and levels
Posted on Nov 04, 2009
  • 8546 Answers
SOURCE: I have Marantz SR5005 receiver
Only you can know what's different pre/post renovation.
I'd start with the 2nd problem as it may feed into the first one.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 11, 2011
I have atomic A-8 subwoofer and philips FR740 receiver. when i turn the amplifier and the subwoofer "on", the subwoofer starts to hum loudly and it is wery annoying. i made all the connections...
The symptom sounds like an open signal shield somewhere and the cable is acting like an antenna for airborne electrical noise.
Disconnect the RCA cable at the sub. Is it still humming? NO? Problem is external to it. YES? Internal. Broken ground somewhere.
Recheck all connections making sure to twist the RCA head as you install it so oxides will be worn off.
Consider what may have changed in the environment regarding electrical devices, motors, magnetic sources. Ensure signal and speaker wires as ar not running are as non-parallel to any power cords as practicable.
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
Watching television or a film my Eltax Atomic a-8.2 subwoofer cuts in and out whenever it feels like it! you can hear it click then the bass cicks in then, even when you know there should be some bass...
most active subbs are desinged to shut off untill they are needed ( extreem bass injection) then they come on try setting your sensitivity to low or off
Jun 18, 2010 | Eltax Atomic A-8.2 Subwoofer
I want to connect my Marantz 1030 amp to a yamaha YST-SW012
use the left input on the sub. It acts as the main input. Hope this helps
Nov 19, 2009 | Car Audio & Video
Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Jun 06, 2009 | JVC KW-AVX800 CD Player
Denon avr 2308 no subwoofer operation
is the sub in speaker set A and sub in set B?
that was my problem on Denon DRA-455 with Eltax Linear 6.5
May 29, 2009 | Denon AVR-2308CI
How do I connect a subwoofer to an amplifier marantz pm-68
double up the speaker and then use the two extra screw to hook sub and center
Feb 10, 2009 | Marantz PM-68 Amplifier
Subwoofer cuts out
Its due to the damaged pin in which you r inserting the subwoofer pin!
Dec 08, 2007 | Audio Players & Recorders
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Marantz SR-4200 Receiver Logo
219 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
