Question about Brother HL 5140 Laser Printer
Black Vertical Line on the paper
When ever i print something theirs always a black vertical line about 1/2 an inch thick that starts on the bottom of the page and then fades away right before it get to the top of the page
  • Brother Master
  • 4,338 Answers
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine;quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. if the issue is there at that point then it would point to the cartridge. if not then the fuser
Let me know....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 21, 2009
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
VIZIO 42" tv has thick black vertical line on left side of screen
The oven paper (referred as ovenable paper some time), is made of wood pulp, coated with food grade silicone oil. It features in smoothness, high-heat resistance and non- stick, etc. The brightness of baking paper is over 88. The sizing value of baking paper is above 0.8.Its strength is more than 3000.
Feb 23, 2013 | Vizio 42 in. LCD TV
3-4" thick vertical line on 42" sanyo plasma tv
its most likly caused by either vert controler along bottom of set or ribbon to that part of the controler if you heard a hissing sound most likly is the controler itself
Jan 28, 2010 | LG 42PC3D 42 in. Plasma Television
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
May 03, 2009 | Canon PIXMA® MP530 All-In-One Printer
Printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
Aug 25, 2008 | HP LaserJet 1020 Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Brother HL 5140 Laser Printer Logo
401 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
