Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
65 in. dlp is brand new and keeps turning itself off.Wait a couple of minutes I can turn it on but the screen is black for about another minute
  • Anonymous Mar 19, 2009
    same exact tv... same exact problem
  • electroman May 11, 2010
    What is the brand and model number?
IT MIGHT BE DIRTY- THIS IS WHAT WAS WRONG WITH MY 52IN AFTER REPLACING THE LAMP LIGHT AND ALOT OF OTHER PEOPLE HAD THE SAME PROBLEM AND COULD NOT FIGGER IT OUT EITHER ?? GOOD LUCK!
I have been trouble shooting this with the dealer for two days and here it is:
The TV sensors are very touchy – and it HATES DIRT so if you replaced the LAMP – go back and RE CLEAN THE FILTER and CLEAN OUT THE LAMP COMPARTMENT with a Blower or a Brush, but first turn off the TV for about 15 minutes. I did not clean out the lamp compartment, and the dealer said that the Fans sense the dirt and will not work because of that.
THEN make sure that your screws are replaced back in the holes in the cover plate that have the little errors over them. The cover plate AGAIN is very sensitive to the functioning of the TV. If you don’t believe me – check it out, when the light is blinking yellow on the status button, PRESS ON the filter cover OR the lamp light cover and see if it the light turns off, because that is what the status light is telling you the problem is about per the owners manual.
Well a clean machine is a happy machine – hope this resolves all your problems and saves everyone a lot of heartache!
Just thought I would share –
Posted on May 01, 2009
No image, but good sound
You need to replace your power supply board. They can be had at www.shopjimmy.com
Jan 08, 2014 | Mitsubishi WD-65C8 65 in. LCD HDTV
Mitsubishi dlp
which of the three lights is flashing red?Let me know and I will assist you with the issue.
Mar 21, 2013 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
My Mitsubishi WD-65638 turns on then flickers and turns off?
Flickering must be due to the fault to lamp itself. If you wish to get more details, check this link.
Mar 03, 2013 | Mitsubishi WD-65638 65" DLP HDTV
My Pyle PLMRXT33WT marine radio keeps turning itself off.
This could be due to a short in one of the speaker connections or a bad/blown speaker which is shorting out.
Jul 31, 2010 | Pyle AMFM CD DET MARINE RADIO R/C
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
However if you wait 5-10 minutes and turn it back on, it will repeat itself...
I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
