Question about HP Photosmart C6180 All-In-One InkJet Printer
How much paper should the paper tray hold. mine
How much paper should the paper tray hold. mine only take maybe 4 sheets. doesn't seem right
  • HP Master
  • 4,338 Answers
100 sheets:
Document & Media Handling Details Input tray - 100 sheets size: 3 in x 5 in - 8.5 in x 24.0 in weight: 60 g/m2 - 280 g/m2 , ADF - 50 sheets , Output tray - 50 sheets size: 3 in x 5 in - 8.5 in x 24.0 in weight: 60 g/m2 - 280 g/m2 , Input tray - 20 sheets - 4 in x 6 in
Does it jam when you put more paper? Maybe there is and obstruction in the tray area.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 21, 2009
Paper get stack in the midle of printer before gets into the fuser
Check the specs and make sure the paper is the appropriate weight (I have found 70 gsm doesn't work in mine as too light). Fan the sheets before inserting them in the cassette or paper tray. Clean the paper path by vacuuming the inside, maybe holding the printer and shaking it so any paper dust falls out. Good luck.
Dec 31, 2013 | Konica Minolta Bizhub C451...
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    Paper jams in first rollers out of paper tray one sheet will feed but several will jam
    Check for wear on the first set of rollers. If they seem fine and your print settings are correct (media type and size) then you may need to replace a small part in the paper tray. When I have seen this issue previously I needed to replace a seperation pad that lifts paper up(spring loaded to raise the paper the right amount as the paper level goes down) and has a rubber pad on top, when the rubber pad gets worn and it no longer 'holds' the bottom sheets that are not supposed to feed.You can get these from brother directly or from service centers/retailers. The part you need is the paper feeding kit, part no. LM6291001 and it looks like this!
    Aug 22, 2011 | Brother DCP-7020 All-In-One Laser Printer
    CLP-315 all at once started to paper jam on every sheet with the paper about 3/4 of the way out of the fuser, partially in the tray. The printing is only on about 3/4 of the page as well. I looked...
    If you make a print, look in the printer driver (ctrl +P, then go to properties) Look if you have selected the correct paper size.
    Laser printers are very sensitive on humidity of the paper, so if this solution doesn't work, it can be that your paper is not good anymore (maybe you store it at a dry/warm/humid place). In that case you can try to use a new pack of paper (from a sealed package).
    Jul 02, 2011 | Samsung CLP 315 Laser Printer
    We have a xerox 3250 printer and it keeps telling close tray. tray is closed seems the detector does not work, where can we find the tray close detector/ Regards, AREXX
    1. Power off the device.
    2. Unplug it from the wall.
    3. Leave unplugged for 5 minutes
    4. Plug it back in and turn it back on.
    5. Test
    If it still does not sense the tray you will need to engage service.
    Jun 30, 2011 | Xerox 250 Sheet Optional Paper Tray Feeder...
    Paper tray doesn't raise on my brothers hl5250dn printer. Says papertray empty
    I have had the same exact problem; make absolutely sure that the exit chute is seating properly. With the exit chute open (as if to clear a paper jam) actuate the white spring loaded clips that hold the exit chute, mine were not traveling to their full extension and by moving them a few times this resolved and the exit chute was held more firmly and the rollers spin the right direction.
    Jan 30, 2011 | Brother Lower Paper Tray Feeder / Tray for...
    My Brother 5250DN is not pulling paper through. What could it be?
    do a test print... see you manual. You hold a button for 3 seonds and it'll print a test page. If that works you should be OK. Make sure that your paper tray is NOT over loaded. Maybe try less paper. Try the manual feed using one sheet of paper
    Oct 27, 2009 | Brother HL 5250DN Laser Printer
    Only prints half way and doesn't grab paper right away
    Here are the steps:
    1.Remove the power cable from the printer.
    2.Remove the paper tray from the printer and leave the
    paper tray door open.
    3.Lightly moisten a lint-free cloth with water.
    4.Use the moistened cloth to gently wipe clean the surface
    of the roller.
    5.Let the feed roller dry before plugging back the AC
    power cord
    6. Fan the paper to keep the sheets from sticking
    7.Place 15 - 20 sheets of paper into the paper tray
    8.Insert the paper tray into the printer.
    9. Make a print.
    If issue persists, call 1.800.235.6325 for repair.
    Sep 24, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
    OKI B4100 paperjam warning
    Acording your explained you need do
    1) clean the input tray roller surface, to make sure it has enough grip force.
    2) looking for a sensor around the roller rear, it could be cause the paper jam there, because if the sensor does not detect any input paper go throug there then should be stoped at roller rear.
    3) if you find a optical sensor there, please use a slft cotton stick to clean its surface. (maybe open some cover needed)
    hope you fix it , ask me any time please!
    May 17, 2009 | OKI B4100 Laser Printer
    Paper Jam
    There is a small clear plastic sheet that is suppose to be in front of the black friction pad in the paper tray. if that sheet is under the pad instead of in front of it you will get this error.
    Mar 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
    HP Photosmart C6180 All-In-One InkJet Printer Logo
    77 people viewed this question
    Ben Johnson
