Question about 2wire (1000-400108-001) Router
How to port forward th 2 wire router from web port 80 and tcp/ip port 6100..?
I bought a lorex cctv model SG19LD804-161 I can't set up the remote access for the cameras please helpme ..
  • 12,061 Answers
Hi, Here is a manual explaining how to do it... lorexstore.lorextechnology.com/ pdfs/SG19LD804-161_CLIENT_MANUAL_EN_R2.pdf -
Posted on Aug 04, 2007
  • electronic & computer repair&  servicre
    Here is another one for Email but may help as theory is same ..
    focusoncctv.lorextechnology.com/
    pdfs/SG19LD804-161%20-%20Email%20Setup.pdf -
SOURCE:
I need to access CCTV over internet.I am using Zyxel router (model P600R T1 v2) which having a static WAN IP provided by ISP.Can please guide me on the steps.Thanks.
first you need to forward TCP ports in your router pls write down which TCP ports used for video , audio and control in your DVR and configure to forward this tcp ports in your router
it can be do one step using disable the DMZ and it will make less sequrity in your internal network
Apr 11, 2013 | Zyxel Prestige 660HW Wireless Router...
IP Camera Port Forwarding
The best way to find out what is being forwarded is to look at the traffic with the Wireshark program. You can install this from the Internet.
Wireshark is perfect for this but you have to learn how to filter traffic or there will be too much information collected. It is also regarded as (a bit of) a burglar tool so don't use it at work without permission.
I would recommend that you connect a PC to a wired port on the inside LAN and configure the router to forward outside requests to the PC. When you run wireshark on the inside PC with a filter that selects for tcp port 80 (or tcp port == 80) you will see traffic forwarded from the router.
Use your outside machine to request a page from the router's outside address and the port you are forwarding. If you have forwarding set up correctly, you should see a TCP connection attempt. If you are not running a web server on the inside PC, there will be no connection so you will only see the SYN packet from.
outside. If you have a web server on port 80, you will see a fair number of packets in both directions. (SYN -- SYN-ACK -- SYN -- some HTTP Headers an HTTP GET / a response and FIN -- FIN-ACK).
Once you see successful port forwarding (your are forwarding TCP packets, right?) at the PC, change the destination of the forwarding to the camera.
This is really technical but Wireshark is so good that it is quite easy to use.
Sep 10, 2012 | Computers & Internet
Need 2 open NAT
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called "opening ports" or "port forwarding."
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
For Belkin router follow this steps
Configuring port forwarding
In order to configure this, you need to know:
- The IP address of the computer or device to have the port forwarded to.
- The port numbers to be used and whether these are TCP or UDP ports
(Note: We recommend you use a computer that has a wired connection to the router.)
Setup steps:
  1. Open a Web Browser on the computer. Type in http://192.168.2.1
  2. In the address bar of the Web Browser type Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit.
  1. Click on Virtual Servers under Firewall in the menu on the left
  1. Enter the following information
    • Disable Firwall
    • Type the port(s) specified by the program manufacture for both of the Inbound port fields
    • Select TCP, UDP, or BOTH for the Type.
    • Private IP address: Enter the IP address of the computer you want grant access too.
    • Type the port(s) specified by the program manufacture for both of the Private port fields.
  1. Click the Apply Changes button
Jan 10, 2011 | Belkin (F5D8231-4) Wireless Router...
I am trying to portforward azareus ip adress 192.168.0.1 dlink dir 165
Port-forwarding allows connections from the network, i.e., to TCP port #80 at the IP-address assigned to your router, to be "forwarded" (much like a switchboard operator at a university)
to any specific TCP port (but usually the identical port-number) on a SPECIFIC computer "inside" your network.
If your router is '192.168.0.1', then it probably will give-out IP-addresses like '192.168.0.100'
and '192.168.0.101', and '192.168.0.102' to the first 3 computers on your network.
So, "port-forwarding" is used to designate one of those 3 IP-addresses as the one to receive/process all the 'TCP port #80' traffic.
On the router's web-interface, on the "port-forwarding" page, just add an entry for 'TCP port #80'.
Dec 22, 2010 | Computers & Internet
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
PlayStation 3 keep getting nat type 3 when need type 2
Hi
I was having problems with my PS3 as well I did the following
updated firmwire
Also I assign static ip address on my PS3 and forward ports used by PS3 to static IP address of PS3 on routers firewall.
Ports used by PS3:
udp 3478
udp 3479
udp 3658
tcp.domain (port 53)
udp.domain (port 53)
tcp.http (port 80)
tcp.https (port 443)
udp.ssdp (port 1900)
tcp.amandaBackupInitiation (10080)
tcp.Jabber SSL/TLS (port 5223)
tcp.10075
tcp.10078
tcp.10079
If your still getting problems configure the PS3 to be in your DMZ.
DMZ will be under applications and gaming. Just look for that setting in your routers setup page and add your PS3 IP address to it.
Mar 15, 2010 | Linksys WRT160N Wireless Router
I have 2 lorex dvr's. both need web access, can it be done
there are a few ways to accomplish this. one way is you will need more then one static ip. one static ip for each machine, you will then be hitting them on the same port but different ip's. the simplest way is to change the web port setting in the lorex dvr from 80 to something else in the second machine.
Dec 22, 2009 | Lorex 4 Channel Business & Home Security...
CAN'T CONNECT TO THE STORE CAMERAS FROM HOME PC
at the deli you need to port forward in your router the web port witch is normally 80 to the ip of the machine.
Dec 15, 2009 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
Network routing problem with Axis Camera's
They would need to be on different TCP or UDP port numbers ... in order to access them from the Internet. I'm guestimating that on the LAN you can access all of them because they are on different RFC1918 IP Addresses (e.g. 192.168.1.10, 20, 30) but same port number (e.g. port 80 for web.)
Once you hop through NAT to get to the Internet you now only have one IP Address. The real Internet IP Address. So now you have to have different port numbers for 2 or more cameras. For example use:
#1 port 80
#2 port 8080
#3 port 8081
#4 port 8082
How about that?
And you will have to forward each of those ports to the correct ip address for the correct camera.
Where's my free restaurant dinner? :-)
Apr 17, 2009 | NetGear DG834G Router
Port forwarding
hi there,
this is a basic step used to forward ports to your system.
Port Forwarding Steps for Routers 1. Log into your router. Usually the URL is http://192.168.1.1/, and enter the username , and the password . If you have never set a password, the password (which you should change) is admin. Consult the manual if you have never set up your router before or need to reset the password. 2. Click on the "Applications & Gaming" tab or Under Advanced, click Port Forwarding.
3. Click on the "Port Range Forward" tab .
4. In the "application" field, type "web" (if you are forwarding wb traffic on port 80) or "torrent" (if you are forwarding bittorrent traffic on port 40156). This is just a "nickname" so that you can recognize what you were trying to do when you come back to it.
5. In the "Start" field, enter: 80
6. In the "End" field, also enter: 80
7. Set "Protocol" to TCP. Web and Bittorrent servers use only TCP, so there's no reason fo forward UDP traffic too and create an unnecessary security risk.
8. In the "IP Address" field, enter: 192.168.1.11 or your system IP address.
9. Click "Save Settings." Forwarding should begin immediately.
Apr 15, 2008 | Computers & Internet
2wire (1000-400108-001) Router Logo
1,534 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
