Question about Gateway FPD1975W 19" LCD Monitor
Gateway 900W FPD1975W Monitor Gamma Setting Issue
Gateway 900W FPD1975W Monitor Gamma Issue - I am trying to calibrate my monitor for photography use and my gamma adjustment on the advanced menu tab is grayed out so I can't adjust Gamma. Any suggestions?
5 Suggested Answers
mdsaeed67
  • 849 Answers
SOURCE: gateway 900w monitor
the back light must be gone bad, need replacement, contact to sevice center
Posted on Oct 27, 2008
  • 60 Answers
SOURCE: FPD1975W 19" gateway monitor
The stand is fix,but you can move up/dn little bit..
Posted on Jul 10, 2009
  • 555 Answers
SOURCE: Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Posted on Oct 09, 2009
budmrtn
  • 11361 Answers
SOURCE: Just recently and not everyday my monitor will go
It may have unstable power supply due to bad caps as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Feb 15, 2011
  • 36 Answers
SOURCE: Gateway monitor FPD2275W TFT LCD powers on,
The back lamps that provide the illumination of the
colors, is shutting down there are feedback circuits when there is a problem
with the lamps it will shut down the lamps. Replacing the lamps should alleviate
this problem. For more information on this email me at Sprint6@zoominternet.net
Posted on Mar 23, 2011
My monitor will not come on. the powere botton is flashing blue
Which model 900w or LE1936 ?
This info is usually on a sticker to the side of the stand.
If the 900w: You problem is probably that the capacitors on the power board have gone bad and need replacing. May also have transistor problems.
You would have to open it up to get a better idea.
I can probably tell from a picture.
If it is the LE1936: then it could be a similar capacitor problem, but it is rarer on this model than the 900w
Also on this model, there is a voltage regulator on the vga-dvi board that tends to go bad.
email bammbamm@ptd.net
Nov 03, 2010 | Gateway FPD1975W 19" LCD Monitor
(small text) color is off -- it looks green while should be black. I am looking for a timing table for Gateway FPD1975W. Thanks
mcdevito75 here Try to press the AUTO button on the monitor to restore factory settings to monitor.
Jul 21, 2010 | Gateway FPD1975W 19" LCD Monitor
My Gateway 19 in model 900w monitor has hit the skids. Help !
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 08, 2010 | Gateway FPD1975W 19" LCD Monitor
Poor resolution
try and reinstall the VGA driver for your system i think it will solve this problem..........maybe the VGA driver is not installed?
Sep 01, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway 900g no power
Try a different working out to make sure its not a wall outlet issue.if you do that and your still not getting power then the monitor is bad and would need to be replaced.
Aug 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Fpd1975w display flashes on and off
what resolution are you setting your screen to? if you are setting it too high or to a resolution/frequency that your monitor doesn't support, it will do this. Try setting it to 800 x 600 w/ 32 bit color and a frequency of 60Hz. If you do this and the monitor still blinks, you may just have a bad DVI cable.
Jul 13, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Oct 18, 2008 | Gateway FPD1975W 19" LCD Monitor
Monitor calibration
In the menu, goto colour temp settings and adjust as needed.
The last item (from memory here) is an option to reset the monitor back to factory defaults, you could try that also.
Hope that solves your issue.
Nov 30, 2007 | BenQ FP72G+ 17" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
466 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
