Question about Cannon Canon i960 Photo Printer
Can't reassemble back the the waste ink pads with the 2 springs
I have a Canon ip1000 printer, which I had opened up for cleaning. However, now can't reinstall the waste ink pads along with the springs. Can anyone send a clear picture where these springs connect to ?
I have the same problem. did you ever find a diagram to help put the springs back in?
Posted on Aug 24, 2009
Wast ink absurber full..error27
Hi
The wast ink absorber full, if you want to clean the ink absorber at home without wast money, i will provide you the example in Canon printer,how clean you ink absorber follow the mention below instruction and remove the error of ink absorber.
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
God Luck
Sep 05, 2011 | Canon PIXMA iP1000
How to remove the ink waste remover for canon ip1000
Hi
Please follow the mention below instruction.
1 Open your printer 2 To protect hands from Ink wear thin latex (or similar) gloves 3 Locate the Waste Ink Pads on the inside of your printer. They are on the right hand side
and are quite small.
4 You can remove the pads and the holder with a gentle pull.
5 Using a tissue, soak up as much ink as possible and clean the area around the waste
ink area.
6 There is one more waste holder in the right back bottom of the printer. A kind of
sponge. There are few screws and plastic parts to be removed and this sponge needs to be
washed, dried and placed again. Be careful and patient. This is no understatement. On the
iP1500 this requires the dismantling of most of the printer. Take a photograph (even with your
cell phone) so you can trace back your steps. On the iP1500 the drive motor on the side (Just
behind the waste ink pads) has to be removed to get to the main sponge. You also need to
take care as you lift the slide/carriage. Below this you find 5 little springs.
7 Carefully replace the holder and the pads. Close printer.
8 Whilst printer is disconnected from the mains power, press and hold the power button
and reconnect to ac power.
9 Release the power button.
10 Press the power button again.
Thank
Aug 22, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
The waste ink absorber is fll. Can I get one and exchange it?
Ink Counter Reset - Canon IP1000/1500
1st Option
1 Unplug power cord
2 Press and hold power button
3 Plug in power cord and switch on power - still holding power
button
4 Still holding power button press resume button 8 times
5 Release power button
6 Press power button to turn on
2nd Option
1 Turn off printer and disconnect power cable
2 Press and hold power button, reconnect power cable and switch power on
3 The indicator (LED) should be GREEN
4 Press and release resume button, still holding power button, the indicator (LED) should be ORANGE
5 Press and release resume button again, still holding power button, the indicator (LED) should be GREEN
6 Release power button
Oct 12, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Waste ink absorber is full. what should i do? so i can use back my printer
Siijakiah, I have successfully taken apart and cleaned the waste ink absorber. My problem came when I was putting it back together. Can't find where the two springs under the ink cartridge rest go.
There are two small hard pads on the right hand side under the ink cartridge rest that are fairly easy to clean (just press gently with a tissue until no more ink comes out) as long as you don't drop them.
There are also two large pads right at the bottom of the printer that need cleaning and this requires that you take your printer apart. I can describe how to take it apart and clean them. I can also describe how to get it nearly back together.
If there is anyone else out there who is kind enough to explain/describe where the springs go, I am sure I would not be the only grateful person.
Aug 18, 2010 | Canon PIXMA iP1000
I need to reassemble the waste ink tray and 2 springs on a Canon Pixma iP1000 printer
Brisguy4u, have you got any of the printer back together? I can help you up to the springs - looking for an answer for that one myself.
Jul 10, 2010 | Canon Office Equipment & Supplies
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
My canon ip1000 printer does't want to respond. it wrote "waste ink absorber is full". what i should do?
Well under where the Ink heads "Park" there is a "waste ink absorber" pad type thing. This needs to be "emptied". You need to look in tour manual for exact instructions.
Feb 11, 2010 | Office Equipment & Supplies
I want to clean my cannon ip1000 ink pads. How d oI do this ?
Open your printer. Locate Waste Ink Pad inside in your Printer, on the right hand side are quite small.
You can remove the pads & holder with a gentle pull.
Using a tissue, soak as much as ink as possible and clean around the waste ink area.
Be careful & Patient.
Whilst the printer is disconnected from the main power. Press and hold the Power Button and reconnect to AC Power.
Release the Power Button & Press the Power Button Again.
If i am helpful to you, please rate me.
Thank you.
Aug 31, 2009 | Cannon Canon i960 Photo Printer
Canon Pixma ip1000 dismantle
Depress power button while plugging the canon pixma ip1000. When you depress the power button, the printer can be used even if the in waste absorber hasn't been replaced.
Apr 15, 2007 | Cannon Canon i960 Photo Printer
Canon ip 1000 waste ink reset
want the software tool to reset the waste ink level for canon inkjet printers
Apr 20, 2006 | HP LaserJet 1020 Printer
Cannon Canon i960 Photo Printer Logo
144 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
