Question about Sony KP-51WS500 51" Rear Projection Television
Sony KP51ws520 Flashes 9 times Pause Flashes 9 times keeps going No Sound No picture or HV STAND BY FDLASHES 9 TIMES AND THE TV WILL NOT TURN ON .I HAVE TRIED UNPLUGGING IT FOR 10 MINUTES AND RE TRYING WITH NO SUCESS.
  • ebramkamp Feb 21, 2009
    same problem had a TV tech take a look at it and says I needs the 3 CRT tubes replaced problem is you can find the red and green tube but nobody has the blue tube even sony does not even have it like they dont even care we bought these TVs
  • 10,594 Answers
9 times blink shows Audio Error in your TV.
Let me know if you want to fix it by yourself.
Posted on Feb 21, 2009
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Jan 13, 2015 | Sony FD Trinitron WEGA KD-27FS170 TV
Trouble code: Standby LED blinks 9 times
You will need to replace the G board on this tv to fix the problem
Aug 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony model no KP51WS520 red light flashes 9 times but wont turn on
Check if the TV is in an AV mode.
Normally if I leave my TV in an AV mode with nothing plugged in, it starts flashing the red led..
If no luck return it
Mar 17, 2012 | Sony Televison & Video
Sony KP51WS520- stand by light flashes 9 times and won't turn on.
Greetings, This is direct from the Sony Service manual
9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound or picture. Fails to start
Because of the intracies and risks of electrocution and radiation in this repair I suggest you arrange for a tech, rather than to attempt it yourself. Often changing the faulty component or the actual boards, fails to resolve the problem totally as it may have become damaged deeper into the circuit.
Thanks for using FIXYA
May 04, 2010 | Televison & Video
Sony KP51WS520- stand by light flashes 9 times and won't turn on. Have unpluged for 4 hours, still won't turn on.
Unplug the tv, take the back off,locate the G board, next look for D 6301,and D 6116,these are diodes,desolder them and replace them,if that didnot fix it,then change the switching regulator also,its also on G board..use a desoldering iron to remove parts, then wick wire to get the access solder off the pin holes to resolder parts.hope this helps.....
Feb 23, 2010 | Sony Televison & Video
Sony Wega Model #KP51WS520
Press in order on the SONY remote "display - 5 - vol. down - power" .that will show diagnostics indicating 9 Zero Cross Detect . You shoud take it to a servicer.
Oct 18, 2009 | Sony KP-51WS520 51" Rear Projection...
How TV's stand by button is flashing 9 times, what
Sounds like one of these Codes for television repair.
Check out the link above, it may be a bulb needed for your DLP television.
Sep 10, 2009 | Sony KP-51WS520 51" Rear Projection...
Projection tv wont turn on
a sony should only blink up to 8 times. If its continuous without any pause that usually means No reply from the jungle (data bus is busy, shorted to ground or held
high), IK video path is defective.
Count your blinks again. let me know.
Jan 21, 2008 | Televison & Video
HV Sound no Picture
Sounds as though there is an intermitant, heat-related problem with the HV transformer. You can order this at a tv parts shop or from Sony (probably more expensive) the part number should be on the part or on a schematic. If not, the parts dealer can look it up from the model number.
Good luck! :)
Dec 27, 2007 | Sony KV-36XBR400 36" TV
Sony KP-51WS500 51" Rear Projection Television Logo
293 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
