Question about Sewing Machines
How does the bobbin fit in a 20 year old Kenmore?
  • 26 Answers
Thread should be winding from the right to left if not turn it over. and lay it in good luck
Posted on Mar 08, 2009
What #holes on 158.1786181 solid state Kenmore sew machine bobbin
Do you mean the lower bobbin spool? It should not matter too much so long as it fits. Try it on a scrap of material and see how it goes.
Mar 02, 2015 | Kenmore Sewing Machines
Serious difficulties threading the bobbin on a Janome 4100QDC - I have sewn a lot, so I cannot understand this being a problem for me - I blame the machine! I didn't have problems with my Bernina, which I...
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Sep 01, 2013 | Kenmore 15516 Mechanical Sewing Machine
I am using my mother's Singer Futura 1000 machine - probably around 20 years old but has been little used until recently. The bobbin thread has started wrapping itself around the bobbin multiple
try changing the needle
check to make sure the top thread has not come off the thread take
up lever
it could also be a problem with the timing and the machine
would have to be checked by a technican
Nov 26, 2012 | Sewing Machines
Bobbin cover will not close
if the bobbin cover won't fit easily over the bobbin the either it's the wrong bobbin for the machine, the bobbin is warped or there is something wrong with the bobbin case
Feb 09, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer Model 2638. What class bobbin do I use? Bobbin package says: consult manual, but it's not in there. Are they interchangeable as long as they fit?
Hi! Your machine uses Class15J bobbins (http://www.singerco.com/accessories/notions.html)
No, bobbins aren't really interchangeable, even if they fit. For example, I have a Kenmore 385 Elite and a Brother SX-8060. One (the Kenmore) uses bobbins with a curved top and bottom. The Brother uses bobbins that are flat on top and bottom. Either bobbin fits in either machine. But if I use a curved top and bottom in the Brother, it clicks and clacks and has a greater tendency to jam than the flat bobbins. Likewise, the Kenmore is just happier with its curved bobbins.
Hope this helps!
Robbie
Feb 16, 2010 | Singer 2638 Mechanical Sewing Machine
Kenmore Sewing Machine Drop-in Bobbin Tension Adjusting Problems
looped stitches are usually caused by improper tension. when the loop is on the upper side, it may be corrected by loosening the top tension or by tightening the lower tension (turn the tension screws on the bobbin a hair at a time)
since using the machine only a few times it is best to clean the machine from dust (can use a can of air) blow air into the bobbin area and between the tension disks and under the throat plate.
make sure the machine is threaded correctly and bobbin is evenly threaded
Aug 26, 2009 | Kenmore Sewing Machines
Kenmore sewing maching model 158.904
I bought mine at Walmrt. They are a Singer product and says it will fit most machines. There are 2 belts in the package and the small one is for bobbin winders. I have a Kenmore 158,904 and it fits perfect.
Nov 10, 2008 | Kenmore Sewing Machines
Sewing Machines Logo
20 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
