Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Brushmotor spindle I sucked up a garbage bag, now the brush motorspindle doent work any more
  • My reply is May 11, 2010
    Have you checked the belt from the motor to the brushes hasn't broken?
There is an automatic breaker that turns of roller brush when there is a blockage to keep it from burning out. You probably just have to restart the roller brush by hitting the gray button next to the red power button on your vacuum .. most people never notice that button until this happens.
Posted on Feb 21, 2009
No suction from my kirby sentria
I just took a stiff piece of coax cable, and took the bag off where it attaches to the main unit, and took the head off ( the part with the brush roll in it) AMD cleaned every thing really well, turning the spindle for the fan while " snaking" it and pulled out a baby sock! Ta-Da! Works like New.
Apr 29, 2012 | Kirby Ultimate G Bagged Upright Vacuum
The spinning brush underneath the vacuum had stopped turning and so when I inspected it, it was totally clogged up with hairs / pieces of cotton that had wrapped around the spindle. I removed the plate at...
most of the time the motor is what dose the sucking as well as driving the brush i think you should take closer look at the belt it might not be on the spindle correctly or it could be streched
Oct 01, 2011 | Dyson DC33 Bagged Upright Vacuum
My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Rollers will not turn
Check the reset button on the brushmotor.
Sep 07, 2009 | Vacuums
The vacuum is not sucking up material. Rather it
Either the bag is full, or the belt is broken that drives the brush on the underneath side of wand.
Jim
Jun 09, 2009 | Kenmore 23313 Whispertone Bagged Canister...
The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Mar 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Not sucking up dirt in upright position
if there is dust flyin around the vacuum u might try lookin for clogs on the bottom where the beater brush pushes the dirt in and maybe where the dirt goes into bag ive used wire clothes hangers to free em up works..hope this helps
Dec 06, 2008 | Dirt Devil Vacuums
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
119 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
