Question about Protron PD-DVR100 DVD Recorder
How to hook up protron pds-2315
I can't hook it up please help. Iam callenged by any electronics
First of all, the PDS-2315 is not a DVR (this question is incorrectly categorized), it is a home theater system. Also, this system is not a receiver -- it is a DVD player (DVD/CD/HDCD/CD-R/CD-RW/Kodak PCD Playback) with a "full function" Karaoke feature with two microphone inputs. If you haven't figured out how to set it up in the past 11 months, this is how you do it.
1. Connect the supplied RCA cables (labled FR, FL, SR, SL, Cen, and SW) to the corresponding RCA connections in the back of the DVD player and the back of the Sub-Woofer.
2. Connect the DVD Player to your television.
A. Video:
There are several options here depending on your available Television inputs: Coax Cable, Component (yellow jack), S-Video and Composite (composite providing the best video resolution and coax the poorest). HDMI is not available. Use s-video or composite if you can. You will note that the composite RCA jacks are colored Orange, Blue, and Green. In a pinch, any RCA Cables will work - just don't cross the color codes between the DVD Player and the television. If you need to use coax you will need a coax to RCA adapter. If your television only has a component jack (yellow), it's a simple connection between the two.
B. Audio:
On the back of the DVD player you'll find two RCA jacks labled "Main R" and "Main L". These will be connected to your Audio Out connections on the back of your television. If you don't have Audio Out RCA jacks on the back of your television, but have an earphone jack, you can purchase an RCA adaptor to make that connection. With rear audio out jacks, you should have an option in your television's audio setup menu to select those outputs. (DO NOT CONFUSE "AUDIO OUT" WITH "AUDIO INPUT" because the will look identical.) If you don't have either of these connections, you will not be able to use the system to listen to television signals.
3. Connect the speakers. Each of the speakers is labled with their position (FR, FL, CEN, SR, SL). The speaker wires are color coded to the spring connectors in the rear of the sub-woofer/amplifier. Press the spring lever and place the wire into the opening. For proper biasing, place the color coded wire into the colored spring connector and the other wire into the black connector for the specified speaker. Connecting the speakers should be very easy. If the ends of the speaker wires become damaged, simply strip the wires back half an inch and connect as above. Place the speakers as specified by their position lables (FL, CEN, FR in front of the television and SL and SR to the right and left of the seating.)
4. Plug it in and power on. You'll need to plug in both the DVD player and the sub-woofer. Press the power button, hit the open/close button on either the DVD player or the remote control and put a disc in the machine. If you don't have a picture or a "Protron" title screen, hit the "P-SCAN" button on the remote (top left corner below the "STANDBY" button).
5. Hit the "SETUP" key and enter your system's information and you're done. Your system will work just like any other DVD player with theatre quality sound. --With the added feature of functioning as a Karaoke machine! Just add proper Karaoke CDs, a couple microphones, a bunch of friends and copius amounts of alcohol . . .
Posted on Jan 08, 2010
I have all the speakers for the protron pds-2315 home theater system. I just need the dvd player.. Where can I find/buy just the dvd player for this system?
You could check the auction sites. I see the whole set on eBay right now for cheap. When bidding, strike at the last 10 seconds to prevent having to bid against yourself.
Jul 05, 2011 | Protron PDS-2315 Theater System
What is protron pds-2315 codes ?
I need the answer to this question also.
My remote got stepped on and need to get another one.
Jan 01, 2011 | Protron PDS-2315 Theater System
I bought a used Protron PDS-2315 surround system. It didn't have a remote. I need to know the model number of the remote so I can order one. Can you help?
You can just get a replacement remote from 1800-remotes or www.remotes.com. All you need is the system number and they can get you one.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Aug 18, 2010 | Audio Players & Recorders
I have a protron dvd pds 2315, hooked up to a Insignia LCD HDTV, the sceen is completely pink when I turn on the dvd player. I am using the 3 color coded video cable and a regular white/red cable for...
Turn on your DVD player, go to your set up button on the DVD remote, go to TV and select p-scan. It fixed my problem. My screen was all blue before I did that. Hope it works
May 07, 2010 | Protron PDS-2315 Theater System
Screen is Perfect just Black and White only...No Color
well a dvd player is only going to playback the media it is reading. So if the dvd is a reproduction of a b/w western then b/w is correct but if you play a dvd from the present then it should be in color unless the tv it is connected to is faulty. Try connecting to another tv to see if problem repeats on another tv
Aug 15, 2009 | Protron PD-800 DVD Player
Pds-2315 surround sound remote control
I am looking for a universal remote that will work the PDS-2315 someone please help
Jan 07, 2008 | Pds Hot Buy Store: PIVA DIGITAL 5.1 Home...
Protron PD-DVR100 DVD Recorder Logo
1,221 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
