Question about NetGear WGR614 Wireless Router
WGR614v8 Channel problems
When I change channel for another one that is free, after 5-10 seconds or up to 1 min, someone's router also switches to same channel that I want to use...
It really drives me mad... Any ideas how to fix it?
And one thing, when I check with Network Stumbler, somebody's ssid changes into mine and vice versa.
I can see for example two ssid "Mike & Marco" which is impossible!
  • 2 more comments
  • Michal Krol Feb 21, 2009
    Yes - WPA-PSK [TKIP] + WPA2-PSK [AES]
  • Michal Krol May 01, 2009
    I've changed SSID many times, ofcourse with channels. Now when I disabled SSID broadcasting and switched to short preamble, it worked for 5-10 mins without lags! And after 1 hour everything came back to normal... I'm really desperated that I can't repair it :C
    I don't belive that nobody have such problem!
    Network Stumbler show gaps during broadcasting all the time and it happens every 20-30 seconds...
    I think I'll give up soon before I'll cause huge damage to my psyche >.<
  •  C. Dante
    C. Dante May 11, 2010
    I just read your post -don't know if you're still working on that...
    Did you try to change your SSID and then disable broadcasting it?
  • My reply is May 11, 2010
    Is your network password protected?
    Problem Solver:
  • 10 Answers
Get into the router configuration www.routerlogin.com .first upgrade the firmware...go to wireless settings.. ...change the channel to no 11
apply
It would work
Posted on Aug 30, 2009
New dell n5010 will nt conect to my home wirless.......... can get on pubic but nt my home one .... and if it does get on will kick off in a few mins but now can nt get on at all ?
Try changing the channel fo the router to 11, default channel interferes with cordless home phones, which broadcast 1/2 of a mile
Mar 13, 2011 | Computers & Internet
Our laptop and our Xbox 360 will not pick up the signal it did but something has happened and now neither will work
Always check the obvious first such as power to the router, all cable connections.
If connections are good then has anyone made any changes to the router recently.
If not then have you added a new cordelss phone or other wireless device to your home.
If not a neighbor may have added a wireless device that is interfering with your router. To check this Google "inssider" and download the free app and install it. Run the app and select the 2.4Ghz option to view all wireless devices within your range. You will see your routers SSID along with all other devices within range. If you see any other devices on the same channel as your device you will need to change the channel of your router. Channels 1,6 and 11 are isolated channels so if you are on channel 6 you would want to change your channel to either 1 or 11. If changing channels doesn't solve the problem and you have rebooted your router the unit may be bad.
Feb 26, 2011 | Linksys Wireless-G WRT54G Router
Hi, the following started to happen: 1. Our wireless Internet recently started to develop problems. The signal drops and using the "View wireless network', our secured home network will not show...
It sounds like you have a problem with a conflicting Wireless signal in your area.
This is caused by another wireless network close by that is on the same channel (or within 5 channels higher or lower) than yours that is causing interference.
You can check this by performing the following:
1. check your wireless network at the moment and see if you can see what the channel number is that is being used at the moment, make a note of this.
2. switch your router off (making sure that any settings that you may have changed on the router have been saved first!).
3. browse for any wireless networks that are in the area, and make a note of the channel numbers that these wireless networks are on. You should find that there is another network on the same, or close to the same, channel number that your wireless network is on.
4. power on your wireless router.
5. whilst the router is coming back on, take a look at the networks that you have found and see if there is a channel that is available that is 5 different from everyone else (ie, if there is a network on channel 1, you will be looking to use channel 6, if there is one on 7 use channel 2, etc). If there is no completely clear channel you may need to try and just look at the strongest signals for a 'free' channel.
6. once your wireless router is back up, log on to the configuration page (may be best to use a wired connection if possible, to avoid disconnections mid-configuration)
7. find the wireless configuration page, and set the channel number to the one worked out in step 5
8. retry the wireless network and see if you get better performance and a more stable connection
Wireless networks are a bit picky when it comes to interference, and they ideally need 5 channels of separation, otherwise the carrier signals can interfere with each other. But with not being able to control your neighbours networks, it can be difficult to get a completely clear channel :)
The other thing to check for is if you have had a change around in the house, and perhaps bought a new appliance (such as baby monitor or cordless phones or a fish tank), as some items can throw out interference to conflict with wireless networks.
Hope that this information is of some assistance to you!
Nov 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How do I change channels on the 4 Port Wireless Router, ADSL2/2+. Need to change from channel 9 to channel 1.
Manual for DSL-2640B:
ftp://ftp.dlink.co.uk/dsl_routers_modems/dsl-2640b/DSL-2640B_Manual_v1.pdf
How to change channels see page 27.
For manual channel setting "Enable Auto Channel Scan" needs to be
disabled / not selected.
Note: default login user and password for the router is both admin.
Login opening Internet Explorer entering http://192.168.1.1 as address page.
Sep 01, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
My Linksys WRT160n seems to be very weak. My
Try rebooting the router first...unplug then plug it back in.
Then check your settings to make sure it's configured properly. For example, it hasn't changed itself to b or g mode, etc.
You may be getting interference from someone else's router. Try changing the channel...1, 6, and 11 are the best as they are separated from each other. Most routers are by default on channel 6, you may find less interference on channels 1 or 11. The freeware program Network Stumbler can tell you what channel other networks in your area are using.
Jul 30, 2009 | Linksys WRT160N Wireless Router
Conflict between wireless router and cordless phone
you should try changing your wireless channel in the router setup.
1) log into your router.
2) go to the wireless setup page.
3) change the 'Wireless Channel' from auto to 1-11.
4) re-boot your router and re-connect to it.
5) use your cordless phone and see if the connection drops out.
6) repeat steps until you have a stable channel
good luck :)
Jan 28, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
Gaming
hello!
-- what is the exact model number of your router?
-- what is the operating system of your computer?
-- are you trying to change the channel wirelessly or directly connected to the router?
1. make sure that your computer is directly connected to the router while changing the channel to avoid frequent disconnection.
Apr 26, 2008 | D-Link AirPlus DI-524 Wireless Router
Westell Versalink 327w -- can't change channel
I followed advice that I read on online about how I needed to get into the router settings, but they failed to explain that the default log in and password were "admin" and "password." I finally found it on another troubleshooting site. I got in, but it would not except any changes. I finally gave up.
A couple of ways later, I tried again and when I accessed the router settings it prompted me to change the default log in and password. After that, I was able to make any changes I wanted. Viola' !!!
~Caliwk
Feb 24, 2008 | Westell Wirespeed VersaLink...
NetGear WGR614 Wireless Router Logo
362 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
