Question about Goodman GMS90703BXA Heater
Goodman ez 1425 blower works but no heat
Is there a pilot light? How do you access it?
    Novelist:
  • 189 Answers
It has electronic ignition. no pilot light.. it uses a hot surface ignitor to light the burners. this device gets red hot (just like looking down into your electric toaster). this hot cherry red device lights your burners
Posted on Mar 28, 2009
Goodman ez-1425 ac copper pipe keeps freezing up
copper pipe freezing on the outside indicates that there is liquid evaporating in the space created by the suction of the compressor
the pipe normally will be insulated to stop atmospheric humidity condensing on the pipe
Suggest that you get in a technician to check gas pressures and ac operation
Aug 06, 2016 | Goodman Heating & Cooling
How do you light the furnace of a goodman ez 1625
We have not lit pilot lights ourselves since 1978 when they outlawed standing pilots in Ca for furnaces. We have electronic ignitions of spark oror hot surface ignition, neither of which can be manually lit.
Do you get any fan action if you flip the fan on from auto?if so, you have power and 24v control power too, I would start there.
Oct 31, 2012 | Goodman Heating & Cooling
I have a Goodman forced air heating system in my attic that's only about 3 years old and I believe the pilot light went out last night in a storm. My problem is that I can't locate the pilot in the unit...
Marc, look for where the gas line enters the furnace and remove the panel adjacent to it. That should gibe you access to the pilot light. Also, look for a pilot access door, near where the gas line enters the furnace. The gas line will either be 1/2" flexible copper tubing. 1/2" black iron pine or 1/2" vinyl coated flexible stainless steel. Look for the lighting instructions inside or on the side of the unit.
Hope this helps you solve the problem.
Mar 24, 2011 | Goodman Heating & Cooling
My pilot light went out so i turned off the
Make sure the blower access panels are on firmly. There is a safety switch on most gas furnaces that will prevent operation in the event the blower access panel is not on or loosened. Also make sure a power switch (sometimes looks like a light switch) was not accidentally left "off". :-)
I hope you find this to be very helpful moving forward.
If the blower access panel is not the problem, let us know and we'll dig deeper. :-)
Apr 26, 2010 | Heating & Cooling
Burner wont stay lite on a ez 1425
Check the reservoir that your condensate lines connect to. I flushed mine out under hot water and that corrected the problem.
Jan 10, 2010 | Goodman GMS90703BXA Heater
We have a Goodman gas pack (PGB 030075-1)and no heat. A/C works fine. We can get the blower to come on but nothing but cold air comes out. Do we have a pilot light on this unit that needs to be lit?
Amy,
There is no pilot light. It is electronic ignition.
If you have a gas supply and it is turned on you have electrical problems inside the unit.
Jan 04, 2010 | Goodman Heating & Cooling
Finding Pilot light on Goodman Model caf024a2a. Cannot seem to find the pilot light...The blower works but no heat.
i think the ca # is for the cooling coil unit - the heater should start with gmXXXXX - if your unit is fairly new - the pilot light electronically when thermostat calls for heat the unit will not light if the burner door is open
Oct 24, 2009 | Goodman Heating & Cooling
Blower works but no heat
If in fact you have the above listed furnace, you do not have a pilot but electronic ignition. You will need to remove the front cover on the furnace, tape down the door safety switch and then have someone help you by turning up your thermostat to a very high setting. Watch and listen inside the furnace. There should be some blinking going on at the control board followed by a small blower fan starting up. Then after 10-15 seconds there should be a click followed by an orange glow viewed thru the viewing window to the burner section. In a few seconds the gas valve should click and the burners will ignite. There is a safety switch that will sense flame and then keep the gas going to the burners. If it does not sense it, it will shut it off within 10 seconds. If all is well so far, your blower will turn on in about 90 seconds after flame. There is a diagnostic code chart on the back side of the access door if you get an error code (blinking) on the control board.
Always check little things like air filter, condensate drain and broken or loose wires.
Nov 05, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
781 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
