Question about Gateway (4000274) Motherboard
I need the cost of a gateway motherboard - Gateway (4000274) Motherboard
    President:
  • 2,653 Answers
I usually price them out on ebay. The easiest way is to find the part number of the motherboard and then do an advance search.
Posted on Feb 21, 2009
I need a motherboard for gateway NV55S07U. AMD Quad A6-3400M procewssor
fix laptops for a living, at the cost of ordering and replacing, your better off replacing the entire thing or seeing how much gateway will charge. Best cost I can get is $179 and Id charge at least $100 to put it in...thats 300 after tax, and those new with maxed out memory are going for 500 bucks
Aug 20, 2012 | Gateway Computers & Internet
A techie told me that the reason my Gateway 7330GZ notebook will not power on is a faulty power distribution IC on the motherboard. The part is impossible to find in my part of the globe (Nairobi, Kenya)...
You need to replace the motherboard. This may not be a cost effective solution.
It may be better to put your money towards a new laptop which will be faster and most likely slightly more than the cost of repairing the Gateway.
You can remove the hard disk from the Gateway and put it into an USB hard drive adapter case and then use it as an external USB hard drive for backups and data transfer.
May 23, 2011 | Gateway 7330GZ Notebook
If I need to repair or replace my gateway mx6448 motherboard, which is most cost-efficient: to repair or replace? How would I know the difference? I am not an expert, but can I do this repair or...
Depends on what is wrong. Is it the DC Power Jack? The jack you plug the AC adapter (Charger) into?
Average cost is around $100 for a DC Power Jack replacement. (It's labor intensive, but the jack itself usually runs around $8 to $14 )
Most computer 'repair' shops do not have the skills required to perform this procedure.
The easy way is to just replace the motherboard. (Also more Ka-ching in the pocket)
Just a typical DC Power Jack replacement,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Disassembling a Gateway MX 6000 series laptop,
http://www.insidemylaptop.com/disassemble-gateway-mx-model-ma2a-series-laptop/
Some designs of the motherboard, have the DC Power Jack mounted in an area on the motherboard, that DC Power Jack failure is a reoccurring failure.
The motherboard cracks in the area the DC Power Jack is mounted. (Breaking the circuit traces)
In this instance it's better to replace the motherboard. Of course it's going to fail later on.
Your question: "Can you replace the motherboard?"
I have confidence in you, I believe you can.
Doesn't take a rocket scientist, but does require patience.
1) Remove ALL Power to the laptop. AC adapter (Charger), and Battery.
2) It would behoove you to buy, and wear an ESD wrist strap. (Electro Static Discharge)
Connect the alligator clip to a good ground source.
I connect to the metal frame of an empty desktop computer case.
(Average cost is around $3 to $8. Look online for reference. Visit computer repair shops, and stores like Radio Shack for purchase)
Your body carries Static electricity. Static will fry out (Short Circuit) the hardware components inside a computer. Especially a Processor.
With wearing an ESD wrist strap, and connecting to a good ground source, your laptop is safe.
3) There may be as many as 60+ screws. There may be 12, or more different types of screws. DO NOT mix them up! Use a multi-compartment container, and label the compartments for the area the screws came out of.
You can use a clean egg container, (Or two) in a pinch. label each egg holder.
4) You may want to take photos, and make notes as you disassemble. Makes a real handy guide for reassembling. Also nice to have if you get interrupted in the middle.
Obtaining a motherboard:
You might check Ebay. Sounds like advertising, but it isn't. Just one of my sources.
Also check Laptops for Parts on Ebay.
Some sell a laptop that has a broken LCD screen as the only fault.
Post questions in a Comment.
This is what the motherboard looks like, (Gateway Support),
http://support.gateway.com/s/Mobile/Q106/BladeK8F/4001199R/4001199Rmv.shtml
Oct 13, 2010 | Gateway Computers & Internet
My gateway mt6705 need a new motherboard
http://cgi.ebay.com/GATEWAY-MT6705-MT6707-MT6709-NOTEBOOK-MOTHERBOARD-/270422175742?cmd=ViewItem&pt=Motherboards&hash=item3ef66aeffe
this may be the cheapest on ..if you do the work itself...it is not that hard ..just have to follow the steps ..and be sure you connect all back ..
to get to teh motherboard you have to remove all..starting with the hinges cover ..than battery ..hdd..dvd ..back lid..and than all screws that keep them together ..(also the heat dispenser..cause the screws are holding it back ...
after that keyboard..mouse pad..the usb ribbon at the side..and anything that crosses between the support ..(probably he lights on the lcd..and the lcd itself..from the hinges screws on the main side..
Good luck ..you'll need it..:D! I know cause I just get my head out from one a few hours ago...:D
May 02, 2010 | Gateway MT6705 Notebook
I need a new graphics card for my GATEWAY 4530GZ Laptop.
The gateway system that you have has integrated video card on the motherboard. You would not be able to put in add on graphics card on the motherboard. As here is no place for it.
The alternative solution could be to purchase a PCMCIA Type II graphics card , that goes into the PCMCIA slot.
Frankly speaking this would not be a cost effective resolution. it would be good to invest in a new laptop instead.
Thanks for using fixya
proton
Aug 14, 2009 | Gateway (4530GZ) PC Notebook
Gateway 6750 notebook needs a new motherboard. Is replacement available
When I need something like this, I Google it.
They are usually available.
Try e-Bay, also. I've generally found replacement parts there.
Paying Gateway for a new motherboard costs BIG bucks!
Aug 04, 2009 | Gateway Computers & Internet
I have a dell laptop and the charger pin is mest up on the laptop
The power port connector is soldered to the motherboard. So, you would need to replace the motherboard (costly). It would not be worth the cost. Sorry.
Jun 12, 2009 | Gateway MT6705 Notebook
Computer will not power up
I attempted to find this information for you and was unable to. Usually the type/model of the motherboard in a prebuilt PC is determined by printed information located by the CPU/Memory slots.
The downside to most prebuilt PCs you buy in the store, is these motherboards are generic motherboards. Gateway orders them from a company that makes them in bulk specifically for their needs. You would be better off trying to buy a new motherboard that matches the specifications of your current one. Here is the specification page for this Gateway PC. You would need to find a new motherboard that matched most, if not all of these features. However, worst case scenario, you may consider contacting Gateway to find out if they still have this board and how much it would cost to buy or have them replace it.
http://support.gateway.com/s/PC/R/4054/4054sp3.shtml
Mar 04, 2009 | Gateway 505GR PC Desktop
Gateway (4000274) Motherboard Logo
164 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
