Question about Namco http://www.us.playstation.com/PSP/Games/Smash_Court_Tennis_3 for PSP
The screen is black,
My psp just stopped playing. The screen stays black. Will not respond to buttons being pressed.
  • 4 Answers
Sometimes the PSP's will freeze for one reason or another. In most cases the psp will turn off within a minute and then restart itself. If not disconnect any power supply and remove the battery for a moment to manually reset it. Hopefully you saved recently.
Posted on Feb 24, 2009
Hey can you help me when I started playing WWE All Stars then after I install the save data it stays on black screen..
every time you starts playing allstars . just press circle when it asks you to save the game data . don't worry . it saves automatically .
Mar 29, 2011 | THQ WWE All-Stars for PSP
HOW TO DOWNLOAD PSP GAME
Hi imohhamed,
Based on your concern, I suggest trying the following steps:
1. Connect the PSP to your PC with a USB cable.
2. Press the "home" button on the PSP
--> at the lower left of the screen you can see the home button.
3. Use the left-right directional buttons to find "Settings", then the up-down buttons to find "USB Connection" on the PSP.
4. Press the "X" button, your PSP should display "USB Connection".
5. Please wait until your computer tells you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:
6. Click on the drive letter that corresponds to the PSP unit.
7. Now look for ISO folder then copy your desired game (ISO file) into the folder.
8. When you're done copying your desired games, press the "O" button on the PSP to get out of USB connect mode.
9. To play the game, Use the left-right arrows to move to the game area, then the up-down arrows to find "Memory Stick". Chose that folder by pressing the "X" button again, and you should be able to play all your favorite game!
Hope it helps,
Thank you for using FixYa,
Feb 02, 2011 | Sony PSP (Piano Black)
After pressing the audio button on my psp the screen would go black and white from bottom to top then would go back to normal what i tried is to take out the memory card and tr to press the audio...
Hi, I've had the same problems for about a month now. I have a psp fat (psp-1000) with cfw. 5.50. I was playing ZHP unlosing ranger when the same thing happened.
I use the lowest brightness setting to lengthen game play time. I keep using the audio button (The one you hold and turns the sounds mute or back.. right?) for the game then when i reset my game (press home and start the gameover..) the brightness suddenly keeps on changing even making the whole screen black. After 5 minutes? it stops but then when i press the down or square, triangle button the brightness changes sometimes thats the only thing the button does.. i found a temporary fix for this, i put it sleep mode then turn it on again and it stops.. the buttons go back to normal, for a while.
It goes on and on even with other games. It just stops after 10 minutes later or more than starts happening again everytime the brightness or audio button is pressed.
We scanned it for viruses on a computer and it just kept on blinking everytime it responded to the scan. No virus were found but after that when we disconnected it from the computer the brightness problem stopped for a good long time.. we avoided pressing the brightness and audio buttons. but recently its happening again.
and now just got worse. I was playing Socom Fireteam, and when you accidentaly go to the start menu, you have to press "select" to exit and continue the game. But the "select" button wont work!
so i quit the game and startover.. when this happened for the 3rd time. When i pressed "home" button and was asked if i really wanted to exit the game i couldnt move to "yes" and couldnt press the "O" or "X" buttons.
So i turned off my psp and when it went back on, I couldnt press anything anymore. except, the volume buttons and select (the vsh menu appears)
I searched for help from the internet, found "disable your vsh menu" remedy.
It worked! but when i played the game, the "cwcheat" menu keeps on appearing (seplugin that appears when you press select button). It wouldnt stop >.<
So we disabled that too.
Now playing God of War Ghost of Sparta, and one part, the start menu kept on appearing! we'd close it so that we could push one of the levers in the game but then it pauses the game again.. it stopped after a while. then it happened again only slight.
Found a comment on a "select button problem" and it said that it was the:
"parts that were Ribbon style, with it was the start and select button and the volume/sound" he had that parts?
found same problems around the net, some posts from 2009.
found decent posts and solutions here:
http://forums.qj.net/psp-general-help/151111-psp-slim-start-button-stuck.html
the best one says buy a new "flex bar" or "home bar". It goes by many names, but it's the metal bar that has all of the bottom row buttons on it (home -> start) It's usually under $10 USD and obviously the right thing to do.
got another comment that says it worked from him when he bought one himself.
Glad I found others, and that I could share this.. wish it makes things better.
Hope it works out for all of us!
Another thing, Merry Christmas!
Dec 02, 2010 | Video Game Consoles & Games
My mp3 player screen went black, it is getting hot on the inside, and when i press the power button and press it to play, i get a repeating noise. computer will not recognize it. and screen stays black,...
my mp3 player screen went black, it is getting hot on the inside, and when i press the power button and press it to play, i get a repeating noise. computer will not recognize it. and screen stays black, what is wrong
Jul 08, 2010 | Philips SA3025/37 Flash MP3 Player
Cannot play games of the umd or memory stick
you are trying to play backed up games which are only playable on a softmodded psp. Sorry, but they will not work on a non-modded psp.
Apr 22, 2009 | Sony PSP (Piano Black)
PSP green power light on but screen stay black
Need more info but are you sure you didn`t press by mistake the brightness button? Try to press it again...
Sep 14, 2008 | Sony PlayStation Portable (PSP) Console
My psp keeps turning off
this happened to me and i think it happens when you play your psp while its charging too much, i got littlebigplanet and i love the game too much. ive been playing it 24/7 (not really) but ever since i started playing it while it was charging, it would do this.
Apr 05, 2008 | Sony PlayStation Portable (PSP) Console
Screen wont turn on
we need every detail about :
who
what
when
where
we need to know exactly what you've done to the psp or where you've left it inorder to help you
Jan 31, 2008 | Sony PlayStation Portable (PSP) Console
Namco http://www.us.playstation.com/PSP/Games/Smash_Court_Tennis_3 for PSP Logo
238 people viewed this question
Top Namco Video Game Consoles & Games Experts
Jim Goldsmith
Jim Goldsmith
EnergeeUK
Level 1 Expert
Are you a Namco Video Game Console and Game Expert? Answer questions, earn points and help others
