Question about Teac FD-05PUB External Floppy Drive
I am trying Windows 7 and need drivers for my TEAC USB hard drive
Windows 7, as yet, doesn't have drivers that work with my USB hard drive. I haven't been able to find drivers anywhere. Has anyone had this problem?
  • jcarp1939 Mar 07, 2009
    Jack, same here. Got everything running on 7 except that. Also find that HP needs to update the PSC 1610 driver for 7. Vista driver works but some of the tabs on the printer preferences don't work
  • Anonymous Mar 07, 2009
    I am beta testing Windows 7 also and have the same problem. I would appreciate notificaton if some finds a solution.
  • 42 Answers
Did you check the company page of the hdd developer recently? the new drivers are getting on the web on a daily basis, aspecially since the vista has a completely new sistem that makes the hardware developers pull their hair out (what have they done to the perfect xp system??)
Posted on Feb 22, 2009
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
Driver for HD-CS500U2 compatible with windows 7
Windows 7 should automatically install and set up the device as soon as you plug it in to the computers usb port. If it doesn't it's probably dead.
Aug 19, 2012 | Computers & Internet
My iomega media xporter hard drive not being detected by my PC having windows 7?
Try your Iomega drive on another computer to make sure it works. if it works on another computer, then come back to your computer with windows 7 and try different usb ports. Maybe one of your usb ports is bad. If your usb ports are ok, then your drive is not compatible with windows 7.
Go to iomega's website and see if they have an update, patch or driver for Windows 7.
Get online and got to www.google.com In the google search box type: "Iomega Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Windows 7 drivers.
May 30, 2012 | Iomega Media Xporter 160 GB USB Hard Drive
Need to update driver for TEAC keyboard tk 8060
You can do the following: try a generic USB keyboard if it works then try your keyboard in another computer running windows 7, so that you will know your keyboard is fine. If so then your windows 7 installation has suffered somehow..
P.S. Sometimes a virus can cause a keyboard or mouse to malfuntion.
Mar 04, 2012 | Computers & Internet
Why doesn't my Verbatim "clip
click start right click on computer select properties then device manager scroll to universal serial bus controllers if you se a yellow question exclamation mark ? ! or a red X you will need to update/reinstall drivers right click select update drivers
once inserted windows 7 should automatically install the drivers
if you computer came with a motherboard disk the drivers could be on it
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem check the usb leads inside your computer usually
usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Sep 06, 2011 | Verbatim VER95327 USB Hard Drive
HI, my maxtor basic 500 Gb doesn't start in Windows 7. After plug it , the SO doesn't see it. Can you help me?
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jun 21, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
Sabrent didn't come with drivers for windows vista and 7
It states online that it is "Plug-in-Play" and that it doesn't need drivers.
Hope this helps!
Remember to give me 4 Thumbs Up for Helping out the Community :)
~~Dayminner
Jun 03, 2011 | Sabrent EC-7F83 Hard Drive Enclosure - 3.5...
My External Hard Drive
Try and find drivers for it on manufactures website. the description does not say windows vista compatable. good luck on finding solution
May 29, 2007 | Teac HD2U80 (HD2U80KIT) 80 GB Hard Drive
Teac FD-05PUB External Floppy Drive Logo
1,724 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
Computer Links
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
