I have an MSI EX700 laptop and I have a problem that when I shutdown my laptop, there will be the flashing sleep light, as if it was in suspend mode and not shutdown. I have formatted the laptop to adress this problem but with no success as it still flashes upon shutdown
    President:
  • 2,653 Answers
You might want to try a bios update. Check out the MSI support webpage to see if there is one. They've probably already addressed this issue. If not send me a message and I'll give you some other ideas.
Posted on Feb 21, 2009
How to Use Shutdown, Sleep, Hibernate Modes for my Laptop?
Shutdown is safer, close all program.
Hibernate is good for long period (e.g. stop during the night). All the data will be saved on the HD.
Suspend is similar to Hibernate mode, but data are copied to the RAM, so if you aren't conneted wtih power cable and battery goin to 0%, you will lost your work that aren't saved.
Oct 18, 2016 | Computers & Internet
How to disable the sleep mode of my msi
Hi Tyrell,
Please try to check this website on how to disable sleep mode on your machine.
1. please unplug your notebook from A/C power and remove the Battery for a few minutes and then re-test? If won't work please check the sites below.
How Do Stop My Laptop From Going Into Sleep Mode eHow
How To Enable or Disable the Standby Mode
May 08, 2014 | MSI "MS-U135DX-1679ZA 10"" Netbook, 10""...
Power light keeps flashing when in sleep mode
It is normal -this indicates that the laptop is in "sleep" mode & NOT in shutdown mode.
Dec 04, 2013 | Acer Computers & Internet
Msi sleep state appears stuck
Remove ALL media, DVD, CD, USB, unplug, remove battery, plug in reboot. OR try to boot to safe mode, open the Control Panel, select Power Options, set to High Performance, Change Plan settings, set SLEEP and Hibernate to Never.
Apr 18, 2013 | MSI L1350D-1672US Netbook
How to wake msi u130 from sleeping?tnx
If it is in sleep pressing any key or moving the mouse will generally wake it up. If you left the computer unplugged in sleep mode then it most likely ran out of power. If your using hibernate I would recommend not using it as it has so many issues.... :) If you have to hit the power button to wake it up then it's either shutdown or in hibernate. FYI there will generally be an amber light on to indicate sleep mode. If no lights it's most likely not in sleep mode.
Comment if you need additional assistance.
Aug 24, 2011 | Acer Aspire One Netbook 8.9" Notebook
Have msi lap top vr601x model when try turn on by power button a half moon icon on keypad flashes on with the power button then after 3 sec turns off what does this mean
the half moon indicate an sleep mode when you open your laptop the sleep mode is already activated thats why it goes to shutdown reason is your sleep mode key is grounded try to consult it to your your dealer
Sep 17, 2009 | MSI VR601 Notebook
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba power led flashing yellow
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
good luck.
Computers & Internet Logo
179 people viewed this question
David Payne
David Payne
