Question about Mintek MDP-1770 Portable DVD Player
Dvd player not reading disk
I have a Mintek MDP 1720 It also gets stuck on loading. Would a child moving the laser arm have broken the driver? I'm just a stay at home mom trying fix things. I have to fix it - it's something in me? Can I get help?
    President:
  • 814 Answers
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Posted on Jun 09, 2009
I load disc, it spins but no pic/sound
you better take it to someone professional in the domain as your portable dvd player seem to have problem with its laser
Oct 04, 2009 | Car Audio & Video
Tip
Known Mintek DVD Code Hacks
window.google_render_ad(); Mintek MDP-1010 / MDP-1020 / MDP-1030 / MDP-1070
  1. Press SETUP
  2. Go to "Preferences"
  3. Press 255 135 (or 225422)
  4. Press LEFT and DOWN quickly
  5. Current RC should be displayed
  6. Press the button for the desired RC (0 = codefree)
  7. Press SETUP
Mintek MDP-1060
  1. Press SETUP
  3. Press 253 135
  4. Press LEFT, DOWN, ENTER, SETUP quickly
  7. Press ENTER, SETUP
Mintek MDP-1720
  1. Press SETUP
  3. Press 215 345 (or 251251)
  7. Press (PLAY,) SETUP
Mintek MPD-1730 / MDP-1770
  1. Press SETUP
  3. Press 251 131
  7. Press SETUP
Mintek MDP-1750 / MDP-1810
  1. Press SETUP
  3. Press 251 345 (or 252315, 251251, 255135, 253135, 251251, 251422 / 212425)
  7. Press SETUP
Mintek MPD-1760 / MDP-1815
  1. Press SETUP
  3. Press 224 455
  7. Press SETUP
Mintek MDP-5860 / MDP-5861
  1. Press SETUP
  3. Press 222 443 (or 222443, 242112, 221441 [->MDP-5861], 224441, 245512)
  7. Press SETUP
Mintek MP 1710
  1. Open & close the disc tray
  2. Push SETUP on the remote control
  3. Push 1, 3, 6, 9
  4. Push the left menu arrow button 3 times -- NOT the |<< or << button
  5. Push the right menu arrow button 1 time -- NOT the >>| or >> button
  6. If you see a new menu item named "VERSION", enter that menu
  7. Change "REGION CODE" to 0
  8. Press SETUP
Mintek DTV-233 / DVA-8700 / DVD-1500 / DVD-1600 / DVD-1710 / DVD-2110 / DVD-2580 / DVD-3610 / DVD-5830 / DVD-8350 no known hacks
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
MIntek MDP-1815
Either the glass laser eye lens is dirty, or faulty. You can first try to clean with rubbing alcohol and cotton swab. If cleaning doesn't help, re-download drivers and cd-rom software. If problem still persists, get new laser eye unit or rom drive
Sep 15, 2009 | Mintek MDP-1815 Portable DVD Player
No disc error
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 22, 2009 | Mintek MDP-1810 Portable DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
Unable to play dvd's on my mintek portable dvd player
I would get an optical laser lense cleaner ( it is basically a cd that has fine soft brushes on the underside to clean the laser lense )
something like :
laser lense cleaner link
Apr 13, 2009 | Mintek MDP-1720 Portable DVD Player
Screen comes on, disk turns, loading starts, and doesnt stop
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
My mintek dvd player says no disk
Dec 07, 2008 | Mintek MDP-1815 Portable DVD Player
Mintek mdp-1720
http://www1.epinions.com/content_209566011012
Try this link from someone with the same problem, and a possible solution. It is simple & got my player working albeit temperamentally.
Jun 07, 2008 | Mintek MDP-1770 Portable DVD Player
Mintek MDP-1720
I took mine to an electronics place to be repaired and they told me the company is out of business and the parts are not available anymore.
Oct 22, 2007 | Mintek MDP-1770 Portable DVD Player
Mintek MDP-1770 Portable DVD Player Logo
592 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
