Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
I have a Kenmore Refriderator with ice maker. It has quit making ice The dial under the cover on the end of the ice maker starts to go around like it is going to spit out the ice. It only goes so far then it reverses with out empting the ice. Any one know the answer?
  • Kenmore Master
  • 3,361 Answers
The mold heater/thermostat is bad.
Solution; replace the ice maker.
Posted on Feb 21, 2009
Kenmore Model 106.53609202 Ice Maker not working
You can test the ice maker by pulling the from cover off and exposing the modular head as they call it. You will see holes around the gear with letters next to them. Take a jumper wire and place one in the M hole and the other end into the N hole. This should kick start the ice maker. When you here a click sound, sometimes you'll see a little spark behind the gear which is normal. When this happens pull the jumper wire out and the ice maker should do its normal cycle. Things to check for also is the fill tube blocked with ice, is the temperature in the freezer below 10 degrees F? These things will cause the ice maker not to work as well.
Sep 05, 2012 | Kenmore Refrigerators
Kenmore Elite fridge Ice Maker quit spitting out ice. There are ice cubes in the maker, but it wont release them to the bin
One thing you can do is clean up the condenser coils, the toe kick plate, and the area around the compressor to where the air flows better and it might start working.Other than that your ice mold thermostat inside the ice maker itself could be bad. They are not to hard to replace on modular type ice makers: themobilian_2492.jpg
Jun 24, 2011 | Kenmore Refrigerators
I have an ED2JHGXRBOO side by side refriderator. I am looking for a manuel to help me trouble shoot. My ice maker has quit working and we think it may be the motor. Thank you
Look like Water valve, Check the OHM on Ice maker valve the red color one, or remove 2 screw that hold the vale, pull it out,, unplug the wire that attached to the valve, also the pull out the tubing that supply water to the ice maker by depress the ring while pull the tubing, make a jump wire wirth the cord plug on one end the other end attach the wire connector with insulated plug in to the ice water supply valve side, you will see if the water come out, if not replace the vale which about $39.95 @ Amazon.com, hope this will help.
Aug 31, 2010 | Refrigerators
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
Ice maker not getting water
Hi, The first thing to check is the inlet tube going through the back wall. Make sure it isn't plugged with ice. If the inlet is open, you can remove the front cover on the ice maker and locate the to holes marked M an N. Use an insulated wire and strip off about 1" on the ends. Insert the wire ends into these hole and see if the white gear on the ice maker head starts to turn. Let it advance through the cycle and see if you can hear the inlet valve hum when calling fpr water. If water enters the icemaker, you will need to replace the head modual board or the whole ice maker. There is not much difference in cast.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot Model 70162990 - not making ice
You've either got a bad timer on the ice maker or the water valve is defective. You need to verify that the timer is moving first. If it isn't try pushing in on the dial on the end of the ice maker. It is under the white square cover at the end of the ice maker, usually towards the door, but in some units it points to the left side wall. If it begins to run when you do that, then the timer is broken. If not then I would say that the valve is defective.
Feb 01, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side ice maker
There are as you can imagine many possible causes for you no ice condition. I will give you the most common problem for the year model you have. I hope this helps you.
You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment.
Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
supertechks
Please don't forget to rate me
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leaking from bottom of refriderator
Is this a self defrost refrig. if it is then it might be doing that, which then you might want to look for the drain that is suppose to drain into this pan. It might be missing the pan try that, let us know thanks.
Dec 07, 2007 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
