Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Shirt caught in the agitator
I have a shirt sleeve caught under the agitator and can't get it out. I guess the I need to remove the agitator - how do I do that? Thanks.
  • bradi259 Feb 21, 2009
    Thanks for the advice, but I tried unscrewing the top cap and pulling, and it won't budge. I pulled very hard and tried using a belt to pull on it too. The model number is WWP 1180G and, i'm not sure how old it is, but it looks to be about 5-10 years. Any more advice would be appreciated. Thanks.
  • GE Master
  • 3,361 Answers
The top of the agitator should unscrew then pull off.
Posted on Feb 21, 2009
Clothing gets caught under the agitator wings like sleeves on shirts, strings on clothing ie hooded sweatshirts.
This is something that happens with most top-load washing machines. As long as the agitator has wings, stuff will get under them. That is one reason that front-load machines are becoming more popular.
May 10, 2015 | Crosley Washing Machines
Shirt caught under agitator how do I get agitator out to unwind shirt
you need to pry the softener dispenser cup off the top of the agitator,then you need a 7/16"socket with an extension to remove the nut located down inside there,then lift the agitator straight upward
Mar 23, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
My sleve is stuck in the spinning deal of my washer, how do i get it out?
Remove the rinse dispenser from the top of the agitator (spinning deal). Unscrew the agitator cap located on top of the agitator which is only hand tightened. Once the plastic agitator cap is removed from the top of the agitator you should see a screw which you will need a socket or an adjustable wrench to remove the screw. The agitator can now be removed by lifting strait up to free the sleeve. My only concern is how the sleeve became lodged under the agitator unless the tub became unbalanced from a heavy load. The other possibility could be the support for the tub is broken and needs to be replaced.
Feb 15, 2011 | Admiral AW22 Top Load Washer
How to remove the agitator to remove a shirt that is caught
according to GE if you have a model made after 1999 you need to have a GE technician remove the agitator as it requires a special tool. :(
Dec 17, 2010 | GE Washing Machines
Clothes are caught under the agitator. How can I
Remove the top part of the agitator or the cap and you should find a bolt in the center. Remove the bolt and pull up on agitator.
98702 is not the model # of the machine. you should find the model # either on top of the machine or in the dryer door area around the frame.
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
The washer ate my favorite Christmas table cloth. It is new, rectangular and no stray edges or hangy things on it. I have gotten half of it out but it is ruined with little holes all over it. I guess it is...
There should be a cap located on top of the agitator. Pry off the cap and under that will be another cap. You can reach in and grap this cap and remove it. You can now see a bolt located deep inside the agitator. You will need a socket and long extention to remove this bolt.
With bolt removed reach to the bottom of the agitator and lift up on the agitator to remove.
After cleaning reinstall the agitator in the opposit way it was removed.
Sometimes if the fabric is fine or thin it can get cought under the agitator and tear.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
Aug 08, 2009 | Kenmore Washing Machines
Can't get the fabric softner cap off
Don't feel foolish as im sure your not the only one this has happened to. to remove the agitator cap you must lift it off, apply slight twisting to it while your doing this. soap can gum it up so you may have to use a straight screwdriver to assist you. once you have done this, there should be EITHER a set screw for an allen key on the SIDE of the agitator OR a 3/8 hex screw in the center or the agitator. there is a spring under this screw so remove both and the agitator should lift staight up. use an old belt underneath the base of the agitator for better results. i hope this has answered your question.
Aug 08, 2009 | GE WJRR4170E Top Load Washer
WM won't spin after sleeve got caught in door
I had this happen. The drive belt had come off. Just take off the bottom panel from the back and reattach the belt.
Jan 27, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
248 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
