Question about Trisonic TS-9861 Hair Trimmer
How do I clear all settings on a Conair ww41 scale? Removing the battery does not work.
  • 39 Answers
The instructions I have do tell you how to reset the scale, but I suggest you remove the battery and leave it out over night that may allow the internal memory time to loose the settings.
Posted on Feb 02, 2010
What battery for conair model f92206-1?
Panasonic CR2032 3V. same battery that most computer motherboards use to keep a trickle charge flowing to retain start-up settings.
Jun 14, 2014 | Conair WW81 Weight Watchers Body...
How do I clear my scale ww41
bathroom light
Apr 28, 2012 | Home
I have a Thinner glass/brass round bathroom scale and I cannot find the battery location. I purchased this about 10 years ago from Frontgate but they couldn't help me. Can you?
I have a 10 year old Thinner bathroom scales also. Apparently the manufacturer designed it to make battery replacement hard so you'd buy a new scales. To replace the battery, if your unit is similar to mine, turn it over, remove all the screws and separate the top and bottom. You'll see the glass window that shows the weight. It is held in place by four tabs that are slightly twisted. Straighten them, lift the glass assembly clear without straining the wires, and turn it over to reveal the round black battery case. It is secured by three small screws and clear epoxy. Remove the epoxy with a knife blade, remove the screws, and separate the two halves of the case on one side being careful not to separate the other side where there is a metal connection piece. Using the knife tip, remove the CR2032 battery and replace it with a new one (available at Radio Shack or similar stores). Reassemble in reverse order; no need to replace epoxy. My scales worked fine after that.
Jan 09, 2011 | Conair WW81 Weight Watchers Body...
We have a WW37GD scale. We recently switched the battery in it and doesn't work correctly. I called Conair and they told me to leave the battery out of it for 3 hours to reset it. I did that, but it...
Ok, please check that you have a CR 2032 battery. There is a CR2025 that looks exactly the same but is doesn't have the same. Check out the link http://en.wikipedia.org/wiki/List_of_battery_sizes which will clearly show you that both of the batteries have different milli amp hours capacity. My scale now works. Kaanjii
Nov 08, 2010 | Conair Health & Beauty
How do you program the Conair WW41 scale?
turn scale on
press set
press user to select your user number
press set
stand on scale to get intial weight
press set
press down arrow to desired end weight
press set
Dec 06, 2009 | Conair Health & Beauty
How do I clear all settings on a Conair ww41 scale>
Did you leave the battery out for a long time, the scale will hold the settings for some time, leave the battery out over night.
Feb 21, 2009 | Trisonic TS-9861 Hair Trimmer
Battery cover
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Nov 18, 2008 | Conair Thinner Scale by TH208 Body Fat...
Conair ww39 glass bathroom scale won't work- batteries in wrong maybe? Help please!
Googled around until I found specifications for an unrelated brand of a similar bathroom scale. It mentioned making sure batteries were flat side uppermost in their compartment, which did the trick.
Sep 25, 2008 | Health & Beauty
Conair WW41 Scale
To totally reset the scale and remove any old data in the users take battery out for 2 hours.
To use the USER functions:
Tap scale to turn it on
When you see "0.0" press
Press SET button. "P-1" will appear and blink
Use UP/DOWN button to select a user number
once desired user number (1-4) appears press SET button to confirm
when 0.0 appears step on scale this will enter your starting weight
press SET to confirm
scale automatically sets a goal weight of 10% below starting. you can raise or lower it by using arrow buttons-Press SET to confirm
Tracking weight
tap, see 0, select user number. Scale displays start weight, then goal weight then 0.0 and you weigh yourself. In the smaller windows it will display last weight and the difference between current and last weight then diff between current and start then diff between current and goal
Aug 24, 2008 | Health & Beauty
Trisonic TS-9861 Hair Trimmer Logo
252 people viewed this question
Top Trisonic Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Trisonic Health and Beauty Expert? Answer questions, earn points and help others
