Question about Trisonic TS-9861 Hair Trimmer
How do I clear all settings on a Conair ww41 scale>
I bought a Conair Weight Watcher scale and P1 already has numbers in it. How do I totally clear the starting weight and target numbers in P1? I have tried removing the battery and that did not work. Anyone have any ideas?
  • 39 Answers
Did you leave the battery out for a long time, the scale will hold the settings for some time, leave the battery out over night.
Posted on Feb 02, 2010
I have two Weight Watcher scales, model WW11D. They weigh 4 lbs differently. One is 2 lbs heavy and the other is 2 lbs light relative to the weight registered at a Weight Watchers meeting. Is there a...
You say, that: "I have two Weight Watcher scales, model WW11D."
Can I have three guesses where you purchased them???
Do they come with any sort of warranty?
Their weight is inaccurate as compared to the official scales when you weigh yourself at the Weight Watchers meeting.
Are the people running the Weight Watchers meetings absolutely and totally unable to provide an answer regarding these scales?
Jul 04, 2011 | Vacuums
Need user manual
I found the PDF file that contains the instructions for the weight watcher scale. Thank you, please let me know if this works for you. http://www.conaircanada.ca/en/pdf/ibs/en_WW66C.pdf
Thank you
May 03, 2010 | Conair Weight Watchers WW-87 Body Fat...
How do you program the Conair WW41 scale?
turn scale on
press set
press user to select your user number
press set
stand on scale to get intial weight
press set
press down arrow to desired end weight
press set
Dec 06, 2009 | Conair Health & Beauty
The numbers on the digital readout are partly
If the display is showing "partial digits" on the display, it means a scale is excessively shaken (sometimes during shipping) it's possible for the LCD to become partially separated from the PCB (Printed Circuit Board). On many models you can gently press on the LCD and it will reconnect. However on many scales it's difficult to reach the LCD (without removing the cover) and thus the scale will often have to be returned to the manufacturer for repair. Contact them at 1-800-326-6247 for the Conair appliance customer service center.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
How do I clear all settings on a Conair ww41 scale? Removing the battery does not work.
The instructions I have do tell you how to reset the scale, but I suggest you remove the battery and leave it out over night that may allow the internal memory time to loose the settings.
Feb 21, 2009 | Trisonic TS-9861 Hair Trimmer
Programming CONAIR WW 35 CHA Weight Watcher Scales
Press Set and choose the P-##(used to help you recognise which user, so skip your P-## and go to another number by using the Up/Down keys, once you have selected a P-## press Set to begin inputting details, you can input details with Up/Down keys with Set to confirm an input.
Jan 19, 2009 | Conair Weight Watchers WW35 Body Fat Glass...
I cannot set another user or reset current user
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Dec 22, 2008 | Conair WW61, Weight Watcher Memory...
Conair WW41 Scale
To totally reset the scale and remove any old data in the users take battery out for 2 hours.
To use the USER functions:
Tap scale to turn it on
When you see "0.0" press
Press SET button. "P-1" will appear and blink
Use UP/DOWN button to select a user number
once desired user number (1-4) appears press SET button to confirm
when 0.0 appears step on scale this will enter your starting weight
press SET to confirm
scale automatically sets a goal weight of 10% below starting. you can raise or lower it by using arrow buttons-Press SET to confirm
Tracking weight
tap, see 0, select user number. Scale displays start weight, then goal weight then 0.0 and you weigh yourself. In the smaller windows it will display last weight and the difference between current and last weight then diff between current and start then diff between current and goal
Aug 24, 2008 | Health & Beauty
Conair weight watchers ww37gd scale
To set
1. Push the set button, you will get ------
2. Push the user
3. Push set again the user number will blink 3 times and show 0.0
4. Get on the scale- when it shows your weight push the set button. This is your start weight
5. Then it will automatically take 10% and show your goal.
6. Push the set button again this will set the goal
To Weigh
1. Push the user number that you set up the P-? number will blink 3 times and show 0.0
2. Get on the scale it will show in this order
a. your weight now
b. your weight since the last time you weighed
c. The total loss toward this goal
d. Total needed to reach your goal
Mar 18, 2008 | Computers & Internet
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Trisonic TS-9861 Hair Trimmer Logo
297 people viewed this question
Top Trisonic Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Trisonic Health and Beauty Expert? Answer questions, earn points and help others
